[GRASS-QA] GRASS QA: mmetz |snap.c | 10 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Apr 23 19:24:23 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/vector/Vlib/snap.c
          Function
Vect_snap_lines(Begins at: 460, Ends at:491)
              |          New Metrics           |Old Metrics|
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       5 |       |           OK |         5 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      32 |       |           OK |        32 |
Conclusion:   | this function is a            OK           |
metrics are OK
Vect_snap_lines_list(Begins at: 80, Ends at:432)
Complexity:   |      37 |       |           OK |        37 |
CalledNBR:    |      79 |       |           OK |        79 |
LOC:          |     353 |       |           OK |       353 |
metrics are OK
add_item(Begins at: 44, Ends at:48)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       2 |     * |      WARNING |         2 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       5 |       |           OK |         5 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
sort_new(Begins at: 435, Ends at:445)
Complexity:   |       3 |   *** |      MONSTER |         3 |
CalledNBR:    |       0 |   *** |      MONSTER |         0 |
LOC:          |      11 |   *** |      MONSTER |        11 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file has 10 potentially cloned functions:
  cmpcatkey  cmp_cat  cmp_field  comp_array  cmp_near  cmp_along  cmp  cmp  cmpcat
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/snap.c clones of sort_new are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_client/select.c  cmpcat
          /var/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_client/select.c  cmpcatkey
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/cindex.c  cmp_cat
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/cindex.c  cmp_field
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.random.cells/init.c  comp_array
          /var/project-manager/grass/grassSVN/grass/trunk/vector/v.distance/main.c  cmp_near
          /var/project-manager/grass/grassSVN/grass/trunk/vector/v.lrs/v.lrs.label/main.c  cmp_along
          /var/project-manager/grass/grassSVN/grass/trunk/vector/v.net.path/path.c  cmp
          /var/project-manager/grass/grassSVN/grass/trunk/vector/v.overlay/util.c  cmp
          /var/project-manager/grass/grassSVN/grass/trunk/vector/v.reclass/main.c  cmpcat
____________________________________________
Threshold grass key metrics values at Thu Apr 23 19:35:32 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
