[GRASS-QA] GRASS QA: neteler |global.h lines.c parse.c report.c ...| 11 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sun Apr 26 03:26:46 EDT 2009
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/vector/v.to.db/global.h
          Class
options(Begins at: 21, Ends at:35)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
value(Begins at: 4, Ends at:17)
          Class
vstat(Begins at: 39, Ends at:49)
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/vector/v.to.db/lines.c
          Function
read_lines(Begins at: 57, Ends at:271)
              |          New Metrics           |Old Metrics|
Complexity:   |      35 |   *** |      MONSTER |        35 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      54 |   *** |      MONSTER |        54 |
LOC:          |     215 |   *** |      MONSTER |       215 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
read_side_cats(Begins at: 10, Ends at:50)
Complexity:   |       9 |     * |      WARNING |         9 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      41 |       |           OK |        41 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
          File :grass/trunk/vector/v.to.db/parse.c
          Function
match(Begins at: 228, Ends at:238)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      11 |       |           OK |        11 |
 at least 1 values are close to an outlier please consider revising code!
parse_command_line(Begins at: 11, Ends at:170)
Complexity:   |      14 |    ** | BABY-MONSTER |        14 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      48 |   *** |      MONSTER |        48 |
LOC:          |     160 |   *** |      MONSTER |       160 |
parse_option(Begins at: 192, Ends at:226)
Complexity:   |      15 |    ** | BABY-MONSTER |        15 |
CalledNBR:    |      14 |     * |      WARNING |        14 |
LOC:          |      35 |       |           OK |        35 |
Conclusion:   | this function is a  BABY-MONSTER           |
parse_units(Begins at: 172, Ends at:190)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      19 |       |           OK |        19 |
Clone analysis:
          File :grass/trunk/vector/v.to.db/report.c
          Function
print_stat(Begins at: 172, Ends at:192)
LOC:          |      21 |       |           OK |        21 |
report(Begins at: 5, Ends at:170)
Complexity:   |      55 |   *** |      MONSTER |        55 |
CalledNBR:    |      58 |   *** |      MONSTER |        58 |
LOC:          |     166 |   *** |      MONSTER |       166 |
Clone analysis:
          File :grass/trunk/vector/v.to.db/units.c
          Function
conv_units(Begins at: 4, Ends at:53)
ParamNBR:     |       0 |       |           OK |         0 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      50 |     * |      WARNING |        50 |
Clone analysis:
          File :grass/trunk/vector/v.to.db/update.c
          Function
srch(Begins at: 239, Ends at:249)
Conclusion:   | this function is a            OK           |
metrics are OK
update(Begins at: 9, Ends at:237)
Complexity:   |      56 |   *** |      MONSTER |        56 |
CalledNBR:    |      50 |   *** |      MONSTER |        50 |
LOC:          |     229 |   *** |      MONSTER |       229 |
Clone analysis:
This file has 11 potentially cloned functions:
  cmp  cmp  cmp  cmp  fcmp  dcmp  dcmp  cmp_exist  cmp  srch_cat
In /var/project-manager/grass/grassSVN/grass/trunk/vector/v.to.db/update.c clones of srch are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_client/copy_tab.c  cmp
          /var/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_client/select.c  cmp
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/array.c  cmp
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/cats.c  cmp
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.coin/make_coin.c  cmp
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.mapcalc/xmedian.c  fcmp
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.mapcalc/xmedian.c  dcmp
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.mapcalc/xmode.c  dcmp
          /var/project-manager/grass/grassSVN/grass/trunk/vector/v.distance/main.c  cmp_exist
          /var/project-manager/grass/grassSVN/grass/trunk/vector/v.extract/extract.c  cmp
          /var/project-manager/grass/grassSVN/grass/trunk/vector/v.what.rast/main.c  srch_cat
____________________________________________
Threshold grass key metrics values at Sun Apr 26 03:38:24 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
