[GRASS-QA] GRASS QA: hcho |write_vect.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Wed Apr 29 22:22:55 EDT 2009
Hello hcho,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/vector/v.in.dxf/write_vect.c
Function
get_field_cat(Begins at: 121, Ends at:223)
| New Metrics |Old Metrics|
Complexity: | 15 | ** | BABY-MONSTER | 15 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 36 | ** | BABY-MONSTER | 36 |
LOC: | 103 | ** | BABY-MONSTER | 103 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
write_done(Begins at: 73, Ends at:119)
Complexity: | 7 | * | WARNING | 7 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 19 | * | WARNING | 19 |
LOC: | 47 | * | WARNING | 47 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
write_vect(Begins at: 14, Ends at:71)
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 30 | ** | BABY-MONSTER | 30 |
LOC: | 58 | * | WARNING | 58 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Apr 29 22:35:22 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
