[GRASS-QA] GRASS QA: mmetz |export_band.c local_proto.h main.c | no
clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Apr 30 11:14:16 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/raster/r.out.gdal/export_band.c
Function
export_band(Begins at: 25, Ends at:303)
| New Metrics |Old Metrics|
Complexity: | 40 | *** | MONSTER | 40 |
ParamNBR: | 9 | *** | MONSTER | 9 |
CalledNBR: | 71 | *** | MONSTER | 71 |
LOC: | 279 | *** | MONSTER | 279 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/raster/r.out.gdal/local_proto.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/raster/r.out.gdal/main.c
Function
AttachMetadata(Begins at: 85, Ends at:101)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 17 | | OK | 17 |
Conclusion: | this function is a OK |
metrics are OK
main(Begins at: 104, Ends at:499)
Complexity: | 50 | *** | MONSTER | 50 |
ParamNBR: | 2 | ** | BABY-MONSTER | 2 |
CalledNBR: | 110 | *** | MONSTER | 110 |
LOC: | 396 | *** | MONSTER | 396 |
supported_formats(Begins at: 37, Ends at:82)
Complexity: | 9 | *** | MONSTER | 9 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 19 | *** | MONSTER | 19 |
LOC: | 46 | *** | MONSTER | 46 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Apr 30 11:26:50 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
