[GRASS-QA] GRASS QA: neteler |main.c visibility.c | no clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Thu Apr 30 11:21:38 EDT 2009
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/vector/v.net.visibility/main.c
Function
add_points(Begins at: 161, Ends at:187)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 27 | | OK | 27 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
count(Begins at: 191, Ends at:227)
Complexity: | 6 | * | WARNING | 6 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 37 | | OK | 37 |
at least 2 values are close to an outlier please consider revising code!
count_new(Begins at: 144, Ends at:157)
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 14 | | OK | 14 |
Conclusion: | this function is a OK |
metrics are OK
load_lines(Begins at: 232, Ends at:263)
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 32 | | OK | 32 |
main(Begins at: 26, Ends at:140)
Complexity: | 13 | ** | BABY-MONSTER | 13 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 55 | *** | MONSTER | 55 |
LOC: | 115 | ** | BABY-MONSTER | 115 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
process_boundary(Begins at: 329, Ends at:371)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
LOC: | 43 | * | WARNING | 43 |
Conclusion: | this function is a BABY-MONSTER |
process_line(Begins at: 285, Ends at:325)
Complexity: | 5 | | OK | 5 |
LOC: | 41 | | OK | 41 |
process_point(Begins at: 265, Ends at:281)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 4 | * | WARNING | 4 |
LOC: | 17 | | OK | 17 |
Clone analysis:
This file does not contain cloned functions
File :grass/branches/develbranch_6/vector/v.net.visibility/visibility.c
Function
construct_visibility(Begins at: 228, Ends at:314)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 33 | ** | BABY-MONSTER | 33 |
LOC: | 87 | * | WARNING | 87 |
handle(Begins at: 117, Ends at:200)
Complexity: | 21 | *** | MONSTER | 21 |
CalledNBR: | 72 | *** | MONSTER | 72 |
LOC: | 84 | * | WARNING | 84 |
init_vis(Begins at: 24, Ends at:111)
Complexity: | 15 | ** | BABY-MONSTER | 15 |
CalledNBR: | 43 | *** | MONSTER | 43 |
LOC: | 88 | * | WARNING | 88 |
report(Begins at: 204, Ends at:224)
CalledNBR: | 10 | * | WARNING | 10 |
LOC: | 21 | | OK | 21 |
visibility_points(Begins at: 317, Ends at:349)
Complexity: | 7 | * | WARNING | 7 |
LOC: | 33 | | OK | 33 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Apr 30 11:34:12 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
