[GRASS-QA] GRASS QA: hcho |file_io.c global.h main.c topidx.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Apr 30 12:00:25 EDT 2009
Hello hcho,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/raster/r.topidx/file_io.c
          Function
getcells(Begins at: 7, Ends at:72)
              |          New Metrics           |Old Metrics|
Complexity:   |      16 |    ** | BABY-MONSTER |        16 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      39 |   *** |      MONSTER |        39 |
LOC:          |      66 |     * |      WARNING |        66 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
putcells(Begins at: 75, Ends at:96)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |      12 |     * |      WARNING |        12 |
LOC:          |      22 |       |           OK |        22 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/raster/r.topidx/global.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/raster/r.topidx/main.c
          Function
main(Begins at: 29, Ends at:71)
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      43 |     * |      WARNING |        43 |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
          File :grass/trunk/raster/r.topidx/topidx.c
          Function
atanb(Begins at: 26, Ends at:276)
Complexity:   |      48 |   *** |      MONSTER |        48 |
CalledNBR:    |     128 |   *** |      MONSTER |       128 |
LOC:          |     251 |   *** |      MONSTER |       251 |
initialize(Begins at: 6, Ends at:23)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      18 |       |           OK |        18 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Apr 30 12:13:00 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
