[GRASS-QA] GRASS QA: mmetz |allocation.c cindex.c list.c plus.c ...|
28 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Apr 30 12:09:32 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/vector/diglib/allocation.c
Function
dig__alloc_space(Begins at: 50, Ends at:88)
| New Metrics |Old Metrics|
Complexity: | 4 | | OK | 4 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 39 | | OK | 39 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
dig__falloc(Begins at: 118, Ends at:131)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 14 | | OK | 14 |
Conclusion: | this function is a OK |
metrics are OK
dig__frealloc(Begins at: 133, Ends at:164)
Complexity: | 5 | | OK | 5 |
ParamNBR: | 4 | * | WARNING | 4 |
LOC: | 32 | | OK | 32 |
dig_alloc_space(Begins at: 33, Ends at:48)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 16 | | OK | 16 |
dig_falloc(Begins at: 91, Ends at:101)
CalledNBR: | 4 | | OK | 4 |
LOC: | 11 | | OK | 11 |
metrics are OK
dig_frealloc(Begins at: 103, Ends at:113)
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/vector/diglib/cindex.c
Function
cmp_cat(Begins at: 134, Ends at:144)
CalledNBR: | 0 | | OK | 0 |
metrics are OK
cmp_field(Begins at: 147, Ends at:157)
metrics are OK
dig_cidx_add_cat(Begins at: 67, Ends at:131)
Complexity: | 10 | * | WARNING | 10 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 65 | * | WARNING | 65 |
at least 3 values are close to an outlier please consider revising code!
dig_cidx_add_cat_sorted(Begins at: 166, Ends at:252)
Complexity: | 13 | ** | BABY-MONSTER | 13 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 87 | * | WARNING | 87 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
dig_cidx_del_cat(Begins at: 261, Ends at:316)
CalledNBR: | 6 | | OK | 6 |
LOC: | 56 | * | WARNING | 56 |
dig_cidx_free(Begins at: 44, Ends at:58)
ParamNBR: | 1 | | OK | 1 |
LOC: | 15 | | OK | 15 |
metrics are OK
dig_cidx_init(Begins at: 29, Ends at:41)
LOC: | 13 | | OK | 13 |
metrics are OK
dig_cidx_sort(Begins at: 323, Ends at:350)
LOC: | 28 | | OK | 28 |
metrics are OK
Clone analysis:
File :grass/trunk/lib/vector/diglib/list.c
Function
dig_init_list(Begins at: 23, Ends at:30)
Complexity: | 1 | | OK | 1 |
LOC: | 8 | | OK | 8 |
metrics are OK
dig_list_add(Begins at: 33, Ends at:51)
LOC: | 19 | | OK | 19 |
metrics are OK
Clone analysis:
File :grass/trunk/lib/vector/diglib/plus.c
Function
dig_free_plus(Begins at: 241, Ends at:250)
LOC: | 10 | | OK | 10 |
metrics are OK
dig_free_plus_areas(Begins at: 173, Ends at:200)
Complexity: | 6 | * | WARNING | 6 |
dig_free_plus_isles(Begins at: 207, Ends at:232)
LOC: | 26 | | OK | 26 |
metrics are OK
dig_free_plus_lines(Begins at: 137, Ends at:166)
LOC: | 30 | | OK | 30 |
metrics are OK
dig_free_plus_nodes(Begins at: 105, Ends at:130)
metrics are OK
dig_init_plus(Begins at: 31, Ends at:98)
LOC: | 68 | * | WARNING | 68 |
dig_load_plus(Begins at: 262, Ends at:327)
Complexity: | 15 | ** | BABY-MONSTER | 15 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 32 | ** | BABY-MONSTER | 32 |
LOC: | 66 | * | WARNING | 66 |
dig_write_areas(Begins at: 437, Ends at:451)
metrics are OK
dig_write_isles(Begins at: 462, Ends at:476)
metrics are OK
dig_write_lines(Begins at: 412, Ends at:426)
metrics are OK
dig_write_nodes(Begins at: 388, Ends at:401)
metrics are OK
dig_write_plus_file(Begins at: 338, Ends at:377)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 22 | * | WARNING | 22 |
LOC: | 40 | | OK | 40 |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file has 12 potentially cloned functions:
dig_write_lines dig_write_isles dig_write_nodes dig_write_lines dig_write_areas dig_write_nodes dig_write_areas dig_write_isles dig_write_lines dig_write_areas dig_write_isles
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus.c clones of dig_write_areas are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus.c dig_write_nodes
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus.c dig_write_lines
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus.c dig_write_isles
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus.c clones of dig_write_isles are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus.c dig_write_areas
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus.c clones of dig_write_lines are:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus.c clones of dig_write_nodes are:
File :grass/trunk/lib/vector/diglib/rbtree.c
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/lib/vector/diglib/struct_alloc.c
Function
dig_alloc_area(Begins at: 189, Ends at:208)
ParamNBR: | 0 | | OK | 0 |
LOC: | 20 | | OK | 20 |
metrics are OK
dig_alloc_areas(Begins at: 149, Ends at:163)
metrics are OK
dig_alloc_cats(Begins at: 272, Ends at:296)
LOC: | 25 | | OK | 25 |
metrics are OK
dig_alloc_isle(Begins at: 211, Ends at:226)
metrics are OK
dig_alloc_isles(Begins at: 171, Ends at:186)
metrics are OK
dig_alloc_line(Begins at: 110, Ends at:119)
metrics are OK
dig_alloc_lines(Begins at: 127, Ends at:141)
metrics are OK
dig_alloc_node(Begins at: 40, Ends at:54)
metrics are OK
dig_alloc_nodes(Begins at: 93, Ends at:107)
metrics are OK
dig_alloc_points(Begins at: 232, Ends at:266)
CalledNBR: | 9 | | OK | 9 |
LOC: | 35 | | OK | 35 |
metrics are OK
dig_area_alloc_isle(Begins at: 325, Ends at:340)
metrics are OK
dig_area_alloc_line(Begins at: 303, Ends at:318)
metrics are OK
dig_isle_alloc_line(Begins at: 348, Ends at:364)
LOC: | 17 | | OK | 17 |
metrics are OK
dig_node_alloc_line(Begins at: 63, Ends at:84)
LOC: | 22 | | OK | 22 |
metrics are OK
dig_out_of_memory(Begins at: 369, Ends at:373)
LOC: | 5 | | OK | 5 |
metrics are OK
Clone analysis:
This file has 16 potentially cloned functions:
dig_alloc_lines dig_area_alloc_line dig_alloc_node dig_isle_alloc_line dig_alloc_nodes dig_alloc_areas dig_area_alloc_line dig_alloc_isle dig_alloc_lines dig_alloc_areas dig_area_alloc_line dig_alloc_nodes dig_alloc_lines dig_alloc_areas dig_alloc_isles
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_alloc_areas are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c dig_alloc_nodes
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c dig_alloc_lines
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c dig_area_alloc_line
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_alloc_isle are:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_alloc_isles are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c dig_isle_alloc_line
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_alloc_lines are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c dig_alloc_areas
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_alloc_node are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c dig_alloc_isle
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_alloc_nodes are:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_area_alloc_line are:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_isle_alloc_line are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c dig_alloc_isles
____________________________________________
Threshold grass key metrics values at Thu Apr 30 12:22:07 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
