[GRASS-QA] GRASS QA: neteler |alloc_cell.c cats.c cellstats_eq.c closecell.c ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Aug 5 09:15:58 EDT 2009
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/raster/alloc_cell.c
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/lib/raster/cats.c
          File :grass/trunk/lib/raster/cellstats_eq.c
          File :grass/trunk/lib/raster/closecell.c
          File :grass/trunk/lib/raster/color_compat.c
          File :grass/trunk/lib/raster/color_free.c
          File :grass/trunk/lib/raster/color_get.c
          File :grass/trunk/lib/raster/color_hist.c
          File :grass/trunk/lib/raster/color_insrt.c
          File :grass/trunk/lib/raster/color_invrt.c
          File :grass/trunk/lib/raster/color_look.c
          File :grass/trunk/lib/raster/color_org.c
          File :grass/trunk/lib/raster/color_range.c
          File :grass/trunk/lib/raster/color_read.c
          File :grass/trunk/lib/raster/color_rule.c
          File :grass/trunk/lib/raster/color_rules.c
          File :grass/trunk/lib/raster/color_set.c
          File :grass/trunk/lib/raster/color_write.c
          File :grass/trunk/lib/raster/color_xform.c
          File :grass/trunk/lib/raster/fpreclass.c
          File :grass/trunk/lib/raster/gdal.c
          File :grass/trunk/lib/raster/get_cellhd.c
          File :grass/trunk/lib/raster/get_row.c
          File :grass/trunk/lib/raster/get_row_colr.c
          File :grass/trunk/lib/raster/histogram.c
          File :grass/trunk/lib/raster/history.c
          File :grass/trunk/lib/raster/histo_eq.c
          File :grass/trunk/lib/raster/init.c
          File :grass/trunk/lib/raster/interp.c
          File :grass/trunk/lib/raster/null_val.c
          File :grass/trunk/lib/raster/opencell.c
          File :grass/trunk/lib/raster/put_cellhd.c
          File :grass/trunk/lib/raster/put_row.c
          File :grass/trunk/lib/raster/put_title.c
          File :grass/trunk/lib/raster/quant.c
          File :grass/trunk/lib/raster/quant_io.c
          File :grass/trunk/lib/raster/quant_rw.c
          File :grass/trunk/lib/raster/R.h
          File :grass/trunk/lib/raster/range.c
          File :grass/trunk/lib/raster/raster.c
          Function
R_RGB_color(Begins at: 172, Ends at:175)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       3 |       |           OK |         3 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       4 |       |           OK |         4 |
Conclusion:   | this function is a            OK           |
metrics are OK
R_begin_scaled_raster(Begins at: 540, Ends at:543)
ParamNBR:     |       3 |     * |      WARNING |         3 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
R_bitmap(Begins at: 557, Ends at:560)
ParamNBR:     |       4 |     * |      WARNING |         4 |
R_box_abs(Begins at: 413, Ends at:416)
R_box_rel(Begins at: 431, Ends at:434)
ParamNBR:     |       2 |       |           OK |         2 |
metrics are OK
R_close_driver(Begins at: 68, Ends at:77)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
R_cont_abs(Begins at: 253, Ends at:256)
metrics are OK
R_cont_rel(Begins at: 275, Ends at:278)
metrics are OK
R_encoding(Begins at: 525, Ends at:528)
metrics are OK
R_end_scaled_raster(Begins at: 552, Ends at:555)
metrics are OK
R_erase(Begins at: 200, Ends at:203)
metrics are OK
R_flush(Begins at: 63, Ends at:66)
metrics are OK
R_font(Begins at: 520, Ends at:523)
metrics are OK
R_font_info(Begins at: 535, Ends at:538)
metrics are OK
R_font_list(Begins at: 530, Ends at:533)
metrics are OK
R_get_num_colors(Begins at: 136, Ends at:139)
metrics are OK
R_get_text_box(Begins at: 506, Ends at:509)
ParamNBR:     |       5 |     * |      WARNING |         5 |
R_line_width(Begins at: 186, Ends at:189)
metrics are OK
R_move_abs(Begins at: 216, Ends at:219)
metrics are OK
R_move_rel(Begins at: 236, Ends at:239)
metrics are OK
R_open_driver(Begins at: 42, Ends at:61)
CalledNBR:    |      13 |     * |      WARNING |        13 |
LOC:          |      20 |       |           OK |        20 |
R_polydots_abs(Begins at: 293, Ends at:296)
R_polydots_rel(Begins at: 313, Ends at:316)
R_polygon_abs(Begins at: 374, Ends at:377)
R_polygon_rel(Begins at: 394, Ends at:397)
R_polyline_abs(Begins at: 334, Ends at:337)
R_polyline_rel(Begins at: 356, Ends at:359)
R_scaled_raster(Begins at: 545, Ends at:550)
ParamNBR:     |       6 |     * |      WARNING |         6 |
LOC:          |       6 |       |           OK |         6 |
R_screen_bot(Begins at: 116, Ends at:119)
ParamNBR:     |       1 |    ** | BABY-MONSTER |         1 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
R_screen_left(Begins at: 88, Ends at:91)
metrics are OK
R_screen_rite(Begins at: 102, Ends at:105)
metrics are OK
R_screen_top(Begins at: 131, Ends at:134)
metrics are OK
R_set_window(Begins at: 469, Ends at:472)
ParamNBR:     |       4 |       |           OK |         4 |
metrics are OK
R_standard_color(Begins at: 153, Ends at:156)
ParamNBR:     |       1 |     * |      WARNING |         1 |
R_text(Begins at: 484, Ends at:487)
metrics are OK
R_text_rotation(Begins at: 451, Ends at:454)
metrics are OK
R_text_size(Begins at: 446, Ends at:449)
metrics are OK
init(Begins at: 25, Ends at:40)
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      16 |       |           OK |        16 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/lib/raster/raster_metadata.c
          File :grass/trunk/lib/raster/reclass.c
          File :grass/trunk/lib/raster/sample.c
          File :grass/trunk/lib/raster/set_window.c
          File :grass/trunk/lib/raster/window_map.c
____________________________________________
Threshold grass key metrics values at Wed Aug 05 09:04:18 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
