[GRASS-QA] GRASS QA: hamish |stroke.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Wed Aug 5 11:24:07 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/lib/symbol/stroke.c
Function
S_stroke(Begins at: 147, Ends at:174)
| New Metrics |Old Metrics|
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 28 | | OK | 28 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
add_coor(Begins at: 24, Ends at:35)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 12 | | OK | 12 |
at least 1 values are close to an outlier please consider revising code!
stroke_chain(Begins at: 42, Ends at:140)
Complexity: | 22 | *** | MONSTER | 22 |
CalledNBR: | 15 | * | WARNING | 15 |
LOC: | 99 | ** | BABY-MONSTER | 99 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Aug 05 11:12:25 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
