[GRASS-QA] GRASS QA: glynn |rasterdefs.h gdal.c get_row.c init.c
...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Wed Aug 5 12:38:31 EDT 2009
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/include/rasterdefs.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/lib/raster/gdal.c
File :grass/trunk/lib/raster/get_row.c
File :grass/trunk/lib/raster/init.c
File :grass/trunk/lib/raster/opencell.c
File :grass/trunk/lib/raster/put_row.c
File :grass/trunk/lib/raster/R.h
File :grass/trunk/lib/raster/set_window.c
File :grass/trunk/lib/raster/window_map.c
____________________________________________
Threshold grass key metrics values at Wed Aug 05 12:26:48 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
