[GRASS-QA] GRASS QA: mmetz |header.c init_head.c open.c | no clones
	| 0 monsters |0 warnings
    soccerlab.info at gmail.com
    Sat Aug  8 05:48:38 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/vector/Vlib/header.c
          Function
Vect__read_head(Begins at: 122, Ends at:192)
              |          New Metrics           |Old Metrics|
Complexity:   |      18 |    ** | BABY-MONSTER |        18 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      62 |   *** |      MONSTER |        62 |
LOC:          |      71 |     * |      WARNING |        71 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Vect__write_head(Begins at: 86, Ends at:112)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |      24 |    ** | BABY-MONSTER |        24 |
LOC:          |      27 |       |           OK |        27 |
Conclusion:   | this function is a  BABY-MONSTER           |
Vect_get_comment(Begins at: 437, Ends at:440)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
Conclusion:   | this function is a            OK           |
metrics are OK
Vect_get_date(Begins at: 303, Ends at:306)
metrics are OK
Vect_get_full_name(Begins at: 225, Ends at:232)
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |       8 |       |           OK |         8 |
metrics are OK
Vect_get_map_date(Begins at: 384, Ends at:387)
metrics are OK
Vect_get_map_name(Begins at: 357, Ends at:360)
metrics are OK
Vect_get_mapset(Begins at: 213, Ends at:216)
metrics are OK
Vect_get_name(Begins at: 201, Ends at:204)
metrics are OK
Vect_get_organization(Begins at: 270, Ends at:273)
metrics are OK
Vect_get_person(Begins at: 330, Ends at:333)
metrics are OK
Vect_get_proj(Begins at: 479, Ends at:482)
metrics are OK
Vect_get_proj_name(Begins at: 497, Ends at:512)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      16 |       |           OK |        16 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Vect_get_scale(Begins at: 410, Ends at:413)
metrics are OK
Vect_get_thresh(Begins at: 536, Ends at:540)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       5 |       |           OK |         5 |
metrics are OK
Vect_get_zone(Begins at: 464, Ends at:467)
metrics are OK
Vect_is_3d(Begins at: 242, Ends at:245)
metrics are OK
Vect_print_header(Begins at: 37, Ends at:46)
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
Vect_read_header(Begins at: 56, Ends at:60)
metrics are OK
Vect_set_comment(Begins at: 423, Ends at:428)
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       6 |       |           OK |         6 |
metrics are OK
Vect_set_date(Begins at: 286, Ends at:291)
metrics are OK
Vect_set_map_date(Begins at: 370, Ends at:375)
metrics are OK
Vect_set_map_name(Begins at: 343, Ends at:348)
metrics are OK
Vect_set_organization(Begins at: 255, Ends at:261)
LOC:          |       7 |       |           OK |         7 |
metrics are OK
Vect_set_person(Begins at: 316, Ends at:321)
metrics are OK
Vect_set_scale(Begins at: 397, Ends at:401)
metrics are OK
Vect_set_thresh(Begins at: 522, Ends at:527)
metrics are OK
Vect_set_zone(Begins at: 450, Ends at:454)
metrics are OK
Vect_write_header(Begins at: 70, Ends at:75)
metrics are OK
lookup(Begins at: 544, Ends at:550)
ParamNBR:     |       4 |     * |      WARNING |         4 |
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/lib/vector/Vlib/init_head.c
          Function
Vect__init_head(Begins at: 35, Ends at:63)
CalledNBR:    |      13 |     * |      WARNING |        13 |
LOC:          |      29 |       |           OK |        29 |
Vect_copy_head_data(Begins at: 73, Ends at:87)
CalledNBR:    |      18 |     * |      WARNING |        18 |
LOC:          |      15 |       |           OK |        15 |
Clone analysis:
          File :grass/trunk/lib/vector/Vlib/open.c
          Function
Vect__open_old(Begins at: 124, Ends at:396)
Complexity:   |      31 |       |           OK |        31 |
ParamNBR:     |       5 |       |           OK |         5 |
CalledNBR:    |     102 |       |           OK |       102 |
LOC:          |     273 |       |           OK |       273 |
metrics are OK
Vect_coor_info(Begins at: 608, Ends at:646)
Complexity:   |       6 |   *** |      MONSTER |         6 |
ParamNBR:     |       2 |     * |      WARNING |         2 |
CalledNBR:    |      11 |   *** |      MONSTER |        11 |
LOC:          |      39 |   *** |      MONSTER |        39 |
Vect_maptype_info(Begins at: 656, Ends at:673)
Complexity:   |       5 |     * |      WARNING |         5 |
CalledNBR:    |       4 |     * |      WARNING |         4 |
LOC:          |      18 |       |           OK |        18 |
 at least 2 values are close to an outlier please consider revising code!
Vect_open_new(Begins at: 514, Ends at:597)
Complexity:   |       8 |       |           OK |         8 |
ParamNBR:     |       3 |       |           OK |         3 |
CalledNBR:    |      43 |       |           OK |        43 |
LOC:          |      84 |       |           OK |        84 |
metrics are OK
Vect_open_old(Begins at: 410, Ends at:413)
Complexity:   |       1 |     * |      WARNING |         1 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       1 |   *** |      MONSTER |         1 |
LOC:          |       4 |     * |      WARNING |         4 |
Vect_open_old_head(Begins at: 464, Ends at:468)
Vect_open_spatial_index(Begins at: 767, Ends at:832)
ParamNBR:     |       1 |     * |      WARNING |         1 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      66 |       |           OK |        66 |
Vect_open_topo(Begins at: 686, Ends at:757)
Complexity:   |       7 |       |           OK |         7 |
CalledNBR:    |      16 |       |           OK |        16 |
LOC:          |      72 |     * |      WARNING |        72 |
Vect_open_update(Begins at: 427, Ends at:449)
Complexity:   |       2 |     * |      WARNING |         2 |
CalledNBR:    |       2 |     * |      WARNING |         2 |
LOC:          |      23 |     * |      WARNING |        23 |
 at least 3 values are close to an outlier please consider revising code!
Vect_open_update_head(Begins at: 482, Ends at:502)
LOC:          |      21 |       |           OK |        21 |
Vect_set_open_level(Begins at: 96, Ends at:107)
LOC:          |      12 |       |           OK |        12 |
fatal_error(Begins at: 59, Ends at:71)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      13 |       |           OK |        13 |
metrics are OK
format(Begins at: 38, Ends at:42)
ParamNBR:     |       0 |       |           OK |         0 |
metrics are OK
open_old_dummy(Begins at: 32, Ends at:35)
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Sat Aug 08 05:35:48 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
