[GRASS-QA] GRASS QA: martinl |gs.c GS2.c | no clones | 0 monsters
|0 warnings
soccerlab.info at gmail.com
Wed Aug 26 13:29:26 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/ogsf/gs.c
Function
gs_att_is_set(Begins at: 149, Ends at:165)
| New Metrics |Old Metrics|
Complexity: | 4 | | OK | 4 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 17 | | OK | 17 |
Conclusion: | this function is a OK |
metrics are OK
gs_delete_surf(Begins at: 463, Ends at:476)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 14 | | OK | 14 |
metrics are OK
gs_distance_onsurf(Begins at: 1417, Ends at:1452)
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 36 | | OK | 36 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
gs_err(Begins at: 34, Ends at:39)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 6 | | OK | 6 |
metrics are OK
gs_free_surf(Begins at: 487, Ends at:546)
Complexity: | 12 | * | WARNING | 12 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 60 | * | WARNING | 60 |
gs_free_unshared_buffs(Begins at: 557, Ends at:588)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 32 | | OK | 32 |
at least 1 values are close to an outlier please consider revising code!
gs_get_att_src(Begins at: 656, Ends at:669)
Complexity: | 3 | | OK | 3 |
metrics are OK
gs_get_att_typbuff(Begins at: 681, Ends at:706)
Complexity: | 5 | | OK | 5 |
ParamNBR: | 3 | | OK | 3 |
LOC: | 26 | | OK | 26 |
metrics are OK
gs_get_att_type(Begins at: 630, Ends at:645)
ParamNBR: | 2 | * | WARNING | 2 |
LOC: | 16 | | OK | 16 |
gs_get_data_avg_zmax(Begins at: 1203, Ends at:1222)
LOC: | 20 | | OK | 20 |
metrics are OK
gs_get_datacenter(Begins at: 1232, Ends at:1281)
Complexity: | 9 | * | WARNING | 9 |
LOC: | 50 | * | WARNING | 50 |
gs_get_last_surface(Begins at: 172, Ends at:185)
metrics are OK
gs_get_new_surface(Begins at: 193, Ends at:216)
CalledNBR: | 4 | | OK | 4 |
LOC: | 24 | | OK | 24 |
metrics are OK
gs_get_prev_surface(Begins at: 86, Ends at:99)
metrics are OK
gs_get_surf(Begins at: 62, Ends at:76)
LOC: | 15 | | OK | 15 |
metrics are OK
gs_get_xextents(Begins at: 1016, Ends at:1022)
LOC: | 7 | | OK | 7 |
metrics are OK
gs_get_xrange(Begins at: 1126, Ends at:1153)
LOC: | 28 | | OK | 28 |
gs_get_yextents(Begins at: 1033, Ends at:1039)
metrics are OK
gs_get_yrange(Begins at: 1164, Ends at:1191)
gs_get_zextents(Begins at: 998, Ends at:1005)
ParamNBR: | 4 | | OK | 4 |
LOC: | 8 | | OK | 8 |
metrics are OK
gs_get_zrange(Begins at: 1088, Ends at:1115)
gs_get_zrange0(Begins at: 1054, Ends at:1077)
metrics are OK
gs_getall_surfaces(Begins at: 108, Ends at:120)
LOC: | 13 | | OK | 13 |
metrics are OK
gs_init(Begins at: 47, Ends at:52)
metrics are OK
gs_init_normbuff(Begins at: 306, Ends at:328)
LOC: | 23 | | OK | 23 |
metrics are OK
gs_init_surf(Begins at: 232, Ends at:296)
ParamNBR: | 7 | ** | BABY-MONSTER | 7 |
LOC: | 65 | * | WARNING | 65 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
gs_malloc_att_buff(Begins at: 718, Ends at:736)
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 19 | | OK | 19 |
gs_malloc_lookup(Begins at: 747, Ends at:792)
Complexity: | 10 | * | WARNING | 10 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 46 | * | WARNING | 46 |
gs_mapcolor(Begins at: 969, Ends at:978)
LOC: | 10 | | OK | 10 |
gs_mask_defined(Begins at: 915, Ends at:918)
Complexity: | 1 | * | WARNING | 1 |
ParamNBR: | 1 | * | WARNING | 1 |
LOC: | 4 | | OK | 4 |
gs_masked(Begins at: 933, Ends at:956)
Complexity: | 6 | | OK | 6 |
metrics are OK
gs_num_datah_reused(Begins at: 597, Ends at:619)
metrics are OK
gs_num_surfaces(Begins at: 127, Ends at:137)
LOC: | 11 | | OK | 11 |
metrics are OK
gs_point_is_masked(Begins at: 1317, Ends at:1403)
Complexity: | 16 | ** | BABY-MONSTER | 16 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 87 | * | WARNING | 87 |
gs_set_att_const(Begins at: 872, Ends at:893)
LOC: | 22 | | OK | 22 |
metrics are OK
gs_set_att_src(Begins at: 828, Ends at:858)
LOC: | 31 | | OK | 31 |
gs_set_att_type(Begins at: 804, Ends at:816)
Complexity: | 2 | * | WARNING | 2 |
gs_set_defaults(Begins at: 441, Ends at:456)
gs_set_maskmode(Begins at: 900, Ends at:905)
gs_setall_norm_needupdate(Begins at: 1290, Ends at:1306)
metrics are OK
print_256lookup(Begins at: 367, Ends at:382)
metrics are OK
print_realto(Begins at: 353, Ends at:358)
metrics are OK
print_surf_fields(Begins at: 391, Ends at:410)
CalledNBR: | 11 | * | WARNING | 11 |
print_view_fields(Begins at: 419, Ends at:432)
CalledNBR: | 8 | | OK | 8 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/ogsf/GS2.c
Function
GS_Get_ClientData(Begins at: 1493, Ends at:1503)
metrics are OK
GS_Set_ClientData(Begins at: 1471, Ends at:1483)
metrics are OK
GS_alldraw_surf(Begins at: 1920, Ends at:1929)
metrics are OK
GS_alldraw_wire(Begins at: 1903, Ends at:1915)
metrics are OK
GS_background_color(Begins at: 2435, Ends at:2438)
metrics are OK
GS_default_draw_color(Begins at: 2422, Ends at:2428)
GS_delete_list(Begins at: 872, Ends at:877)
metrics are OK
GS_delete_surface(Begins at: 1552, Ends at:1580)
LOC: | 29 | | OK | 29 |
metrics are OK
GS_done_draw(Begins at: 2487, Ends at:2499)
CalledNBR: | 3 | * | WARNING | 3 |
LOC: | 13 | * | WARNING | 13 |
at least 4 values are close to an outlier please consider revising code!
GS_draw_X(Begins at: 623, Ends at:654)
CalledNBR: | 11 | | OK | 11 |
GS_draw_all_list(Begins at: 860, Ends at:865)
ParamNBR: | 1 | ** | BABY-MONSTER | 1 |
GS_draw_flowline_at_xy(Begins at: 739, Ends at:796)
Complexity: | 8 | * | WARNING | 8 |
LOC: | 58 | * | WARNING | 58 |
at least 3 values are close to an outlier please consider revising code!
GS_draw_fringe(Begins at: 806, Ends at:813)
CalledNBR: | 2 | * | WARNING | 2 |
GS_draw_legend(Begins at: 829, Ends at:837)
ParamNBR: | 6 | * | WARNING | 6 |
CalledNBR: | 1 | * | WARNING | 1 |
LOC: | 9 | | OK | 9 |
GS_draw_lighting_model(Begins at: 922, Ends at:966)
CalledNBR: | 15 | | OK | 15 |
LOC: | 45 | | OK | 45 |
metrics are OK
GS_draw_lighting_model1(Begins at: 882, Ends at:914)
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 33 | | OK | 33 |
GS_draw_line_onsurf(Begins at: 662, Ends at:687)
ParamNBR: | 5 | | OK | 5 |
CalledNBR: | 10 | | OK | 10 |
metrics are OK
GS_draw_list(Begins at: 847, Ends at:852)
metrics are OK
GS_draw_nline_onsurf(Begins at: 701, Ends at:728)
ParamNBR: | 7 | | OK | 7 |
GS_draw_surf(Begins at: 1848, Ends at:1874)
LOC: | 27 | | OK | 27 |
GS_draw_wire(Begins at: 1883, Ends at:1896)
GS_get_SDscale(Begins at: 1086, Ends at:1091)
GS_get_SDsurf(Begins at: 1066, Ends at:1077)
LOC: | 12 | | OK | 12 |
GS_get_att(Begins at: 1121, Ends at:1145)
Complexity: | 5 | * | WARNING | 5 |
CalledNBR: | 4 | * | WARNING | 4 |
LOC: | 25 | * | WARNING | 25 |
GS_get_cat_at_xy(Begins at: 1164, Ends at:1214)
CalledNBR: | 16 | | OK | 16 |
LOC: | 51 | | OK | 51 |
metrics are OK
GS_get_dims(Begins at: 2263, Ends at:2275)
GS_get_drawmode(Begins at: 2093, Ends at:2106)
metrics are OK
GS_get_drawres(Begins at: 2239, Ends at:2255)
GS_get_exag_guess(Begins at: 2290, Ends at:2330)
CalledNBR: | 5 | | OK | 5 |
LOC: | 41 | | OK | 41 |
GS_get_focus(Begins at: 2549, Ends at:2561)
metrics are OK
GS_get_fov(Begins at: 2841, Ends at:2844)
metrics are OK
GS_get_from(Begins at: 2711, Ends at:2718)
metrics are OK
GS_get_from_real(Begins at: 2725, Ends at:2731)
metrics are OK
GS_get_longdim(Begins at: 135, Ends at:142)
metrics are OK
GS_get_maskmode(Begins at: 1447, Ends at:1460)
metrics are OK
GS_get_modelposition(Begins at: 517, Ends at:540)
metrics are OK
GS_get_modelposition1(Begins at: 488, Ends at:505)
LOC: | 18 | | OK | 18 |
metrics are OK
GS_get_norm_at_xy(Begins at: 1228, Ends at:1274)
ParamNBR: | 4 | * | WARNING | 4 |
LOC: | 47 | * | WARNING | 47 |
GS_get_nozero(Begins at: 2148, Ends at:2171)
GS_get_region(Begins at: 151, Ends at:159)
GS_get_selected_point_on_surface(Begins at: 2974, Ends at:3408)
Complexity: | 16 | | OK | 16 |
ParamNBR: | 42 | | OK | 42 |
CalledNBR: | 52 | | OK | 52 |
LOC: | 435 | | OK | 435 |
metrics are OK
GS_get_surf_list(Begins at: 1525, Ends at:1542)
metrics are OK
GS_get_to(Begins at: 2781, Ends at:2788)
Complexity: | 1 | ** | BABY-MONSTER | 1 |
ParamNBR: | 1 | *** | MONSTER | 1 |
CalledNBR: | 2 | *** | MONSTER | 2 |
LOC: | 8 | *** | MONSTER | 8 |
Conclusion: | this function is a MONSTER |
GS_get_to_real(Begins at: 2738, Ends at:2749)
metrics are OK
GS_get_trans(Begins at: 2398, Ends at:2414)
metrics are OK
GS_get_twist(Begins at: 2851, Ends at:2854)
metrics are OK
GS_get_val_at_xy(Begins at: 1294, Ends at:1367)
Complexity: | 9 | | OK | 9 |
CalledNBR: | 26 | | OK | 26 |
LOC: | 74 | | OK | 74 |
GS_get_viewdir(Begins at: 2795, Ends at:2800)
metrics are OK
GS_get_wire_color(Begins at: 2022, Ends at:2035)
CalledNBR: | 1 | ** | BABY-MONSTER | 1 |
LOC: | 14 | * | WARNING | 14 |
GS_get_zextents(Begins at: 2652, Ends at:2663)
metrics are OK
GS_get_zrange(Begins at: 2675, Ends at:2704)
LOC: | 30 | | OK | 30 |
metrics are OK
GS_get_zrange_nz(Begins at: 2340, Ends at:2366)
GS_getlight_ambient(Begins at: 410, Ends at:422)
GS_getlight_color(Begins at: 366, Ends at:378)
Complexity: | 3 | * | WARNING | 3 |
GS_getlight_position(Begins at: 321, Ends at:336)
metrics are OK
GS_global_exag(Begins at: 1983, Ends at:1988)
metrics are OK
GS_is_masked(Begins at: 996, Ends at:1009)
metrics are OK
GS_libinit(Begins at: 95, Ends at:126)
metrics are OK
GS_lights_off(Begins at: 428, Ends at:437)
metrics are OK
GS_lights_on(Begins at: 442, Ends at:451)
Complexity: | 2 | *** | MONSTER | 2 |
CalledNBR: | 1 | *** | MONSTER | 1 |
LOC: | 10 | *** | MONSTER | 10 |
GS_load_att_map(Begins at: 1593, Ends at:1841)
Complexity: | 42 | | OK | 42 |
CalledNBR: | 64 | | OK | 64 |
LOC: | 249 | | OK | 249 |
metrics are OK
GS_look_here(Begins at: 2925, Ends at:2958)
LOC: | 34 | | OK | 34 |
metrics are OK
GS_moveto(Begins at: 2603, Ends at:2626)
metrics are OK
GS_moveto_real(Begins at: 2633, Ends at:2639)
metrics are OK
GS_new_light(Begins at: 254, Ends at:284)
metrics are OK
GS_new_surface(Begins at: 219, Ends at:246)
metrics are OK
GS_num_surfs(Begins at: 1510, Ends at:1513)
metrics are OK
GS_ready_draw(Begins at: 2474, Ends at:2482)
metrics are OK
GS_set_Narrow(Begins at: 554, Ends at:615)
LOC: | 62 | | OK | 62 |
GS_set_SDscale(Begins at: 1051, Ends at:1056)
GS_set_SDsurf(Begins at: 1030, Ends at:1042)
GS_set_att_const(Begins at: 1398, Ends at:1409)
GS_set_att_defaults(Begins at: 167, Ends at:179)
GS_set_draw(Begins at: 2445, Ends at:2469)
LOC: | 25 | | OK | 25 |
metrics are OK
GS_set_drawmode(Begins at: 2067, Ends at:2082)
metrics are OK
GS_set_drawres(Begins at: 2205, Ends at:2230)
Complexity: | 4 | * | WARNING | 4 |
GS_set_exag(Begins at: 1937, Ends at:1954)
metrics are OK
GS_set_focus(Begins at: 2506, Ends at:2517)
GS_set_focus_center_map(Begins at: 2568, Ends at:2596)
metrics are OK
GS_set_focus_real(Begins at: 2524, Ends at:2537)
metrics are OK
GS_set_fov(Begins at: 2829, Ends at:2834)
metrics are OK
GS_set_global_exag(Begins at: 1961, Ends at:1976)
metrics are OK
GS_set_infocus(Begins at: 2887, Ends at:2894)
metrics are OK
GS_set_maskmode(Begins at: 1422, Ends at:1436)
metrics are OK
GS_set_nofocus(Begins at: 2873, Ends at:2880)
metrics are OK
GS_set_nozero(Begins at: 2115, Ends at:2136)
metrics are OK
GS_set_trans(Begins at: 2374, Ends at:2390)
LOC: | 17 | * | WARNING | 17 |
GS_set_twist(Begins at: 2863, Ends at:2868)
metrics are OK
GS_set_viewdir(Begins at: 2809, Ends at:2822)
GS_set_viewport(Begins at: 2901, Ends at:2909)
metrics are OK
GS_set_wire_color(Begins at: 1998, Ends at:2011)
metrics are OK
GS_setall_drawmode(Begins at: 2045, Ends at:2056)
GS_setall_drawres(Begins at: 2182, Ends at:2193)
metrics are OK
GS_setlight_ambient(Begins at: 388, Ends at:402)
metrics are OK
GS_setlight_color(Begins at: 344, Ends at:358)
GS_setlight_position(Begins at: 295, Ends at:311)
metrics are OK
GS_surf_exists(Begins at: 189, Ends at:207)
metrics are OK
GS_switchlight(Begins at: 459, Ends at:470)
metrics are OK
GS_transp_is_set(Begins at: 478, Ends at:481)
metrics are OK
GS_unset_SDsurf(Begins at: 1014, Ends at:1020)
metrics are OK
GS_unset_att(Begins at: 1379, Ends at:1387)
metrics are OK
GS_update_curmask(Begins at: 978, Ends at:984)
metrics are OK
GS_update_normals(Begins at: 1100, Ends at:1107)
metrics are OK
GS_zoom_setup(Begins at: 2758, Ends at:2772)
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
void_func(Begins at: 83, Ends at:86)
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Wed Aug 26 13:08:02 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
