[GRASS-QA] GRASS QA: hamish |daemon.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Aug 26 15:29:01 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c
          Function
disposeAreas(Begins at: 475, Ends at:611)
              |          New Metrics           |Old Metrics|
Complexity:   |      17 |    ** | BABY-MONSTER |        17 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      43 |   *** |      MONSTER |        43 |
LOC:          |     137 |    ** | BABY-MONSTER |       137 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
error_Output(Begins at: 649, Ends at:662)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      14 |       |           OK |        14 |
Conclusion:   | this function is a            OK           |
metrics are OK
next_Area(Begins at: 613, Ends at:630)
ParamNBR:     |       4 |     * |      WARNING |         4 |
LOC:          |      18 |       |           OK |        18 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
parseSetup(Begins at: 286, Ends at:473)
Complexity:   |      13 |    ** | BABY-MONSTER |        13 |
CalledNBR:    |     107 |   *** |      MONSTER |       107 |
LOC:          |     188 |   *** |      MONSTER |       188 |
print_Output(Begins at: 632, Ends at:647)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      16 |       |           OK |        16 |
metrics are OK
raster_Output(Begins at: 664, Ends at:677)
CalledNBR:    |       6 |       |           OK |         6 |
write_raster(Begins at: 678, Ends at:709)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |      16 |     * |      WARNING |        16 |
LOC:          |      32 |       |           OK |        32 |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Aug 26 15:07:35 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
