[GRASS-QA] GRASS QA: hamish |daemon.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Wed Aug 26 16:12:26 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c
Function
disposeAreas(Begins at: 475, Ends at:611)
| New Metrics |Old Metrics|
Complexity: | 17 | ** | BABY-MONSTER | 17 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 43 | *** | MONSTER | 43 |
LOC: | 137 | ** | BABY-MONSTER | 137 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
error_Output(Begins at: 649, Ends at:662)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 14 | | OK | 14 |
Conclusion: | this function is a OK |
metrics are OK
next_Area(Begins at: 613, Ends at:630)
ParamNBR: | 4 | * | WARNING | 4 |
LOC: | 18 | | OK | 18 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
parseSetup(Begins at: 286, Ends at:473)
Complexity: | 13 | ** | BABY-MONSTER | 13 |
CalledNBR: | 107 | *** | MONSTER | 107 |
LOC: | 188 | *** | MONSTER | 188 |
print_Output(Begins at: 632, Ends at:647)
CalledNBR: | 3 | | OK | 3 |
LOC: | 16 | | OK | 16 |
metrics are OK
raster_Output(Begins at: 664, Ends at:677)
CalledNBR: | 6 | | OK | 6 |
write_raster(Begins at: 678, Ends at:709)
Complexity: | 6 | * | WARNING | 6 |
CalledNBR: | 16 | * | WARNING | 16 |
LOC: | 32 | | OK | 32 |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Aug 26 15:50:59 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
