[GRASS-QA] GRASS QA: hamish |main.c | 6 clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Wed Aug 26 16:56:10 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/raster/r.sun/main.c
Function
INPUT(Begins at: 494, Ends at:690)
| New Metrics |Old Metrics|
Complexity: | 47 | | OK | 47 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 74 | | OK | 74 |
LOC: | 197 | | OK | 197 |
Conclusion: | this function is a OK |
metrics are OK
OUTGR(Begins at: 692, Ends at:822)
Complexity: | 35 | *** | MONSTER | 35 |
CalledNBR: | 50 | *** | MONSTER | 50 |
LOC: | 131 | *** | MONSTER | 131 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
brad(Begins at: 1494, Ends at:1521)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 28 | | OK | 28 |
metrics are OK
calculate(Begins at: 1192, Ends at:1468)
Complexity: | 47 | * | WARNING | 47 |
CalledNBR: | 71 | * | WARNING | 71 |
LOC: | 277 | * | WARNING | 277 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
com_declin(Begins at: 1482, Ends at:1492)
Complexity: | 1 | * | WARNING | 1 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 11 | | OK | 11 |
at least 1 values are close to an outlier please consider revising code!
com_par(Begins at: 865, Ends at:936)
Complexity: | 8 | | OK | 8 |
CalledNBR: | 17 | | OK | 17 |
LOC: | 72 | | OK | 72 |
metrics are OK
com_par_const(Begins at: 825, Ends at:862)
Complexity: | 6 | | OK | 6 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 38 | | OK | 38 |
metrics are OK
com_sol_const(Begins at: 1470, Ends at:1479)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | * | WARNING | 1 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 10 | | OK | 10 |
cube(Begins at: 1153, Ends at:1158)
Complexity: | 2 | * | WARNING | 2 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 6 | * | WARNING | 6 |
at least 2 values are close to an outlier please consider revising code!
distance(Begins at: 140, Ends at:149)
Complexity: | 2 | *** | MONSTER | 2 |
ParamNBR: | 4 | | OK | 4 |
CalledNBR: | 2 | *** | MONSTER | 2 |
LOC: | 10 | *** | MONSTER | 10 |
drad(Begins at: 1523, Ends at:1577)
Complexity: | 8 | *** | MONSTER | 8 |
CalledNBR: | 7 | * | WARNING | 7 |
LOC: | 55 | ** | BABY-MONSTER | 55 |
joules2(Begins at: 980, Ends at:1110)
Complexity: | 22 | * | WARNING | 22 |
CalledNBR: | 11 | | OK | 11 |
LOC: | 131 | | OK | 131 |
lumcline2(Begins at: 940, Ends at:978)
Complexity: | 7 | *** | MONSTER | 7 |
LOC: | 39 | *** | MONSTER | 39 |
main(Begins at: 152, Ends at:491)
Complexity: | 21 | | OK | 21 |
CalledNBR: | 109 | | OK | 109 |
LOC: | 340 | | OK | 340 |
metrics are OK
new_point(Begins at: 1115, Ends at:1124)
CalledNBR: | 0 | *** | MONSTER | 0 |
LOC: | 10 | ** | BABY-MONSTER | 10 |
searching(Begins at: 1160, Ends at:1186)
Complexity: | 6 | * | WARNING | 6 |
LOC: | 27 | | OK | 27 |
test(Begins at: 1579, Ends at:1593)
Complexity: | 2 | | OK | 2 |
LOC: | 15 | | OK | 15 |
metrics are OK
where_is_point(Begins at: 1126, Ends at:1151)
CalledNBR: | 2 | | OK | 2 |
LOC: | 26 | | OK | 26 |
metrics are OK
Clone analysis:
This file has 6 potentially cloned functions:
distance distance distance test test
In /var/project-manager/grass/grassSVN/grass/trunk/raster/r.sun/main.c clones of distance are:
/tmp/grassSVN/grass-addons/raster/r.sun_horizon/r.horizon/main.c distance
/tmp/grassSVN/grass-addons/raster/r.sun_horizon/r.sun2/main.c distance
/var/project-manager/grass/grassSVN/grass-addons/raster/r.sun_horizon/r.horizon/main.c distance
/var/project-manager/grass/grassSVN/grass-addons/raster/r.sun_horizon/r.sun2/main.c distance
In /var/project-manager/grass/grassSVN/grass/trunk/raster/r.sun/main.c clones of test are:
/tmp/grassSVN/grass-addons/raster/r.sun_horizon/r.sun2/main.c test
/var/project-manager/grass/grassSVN/grass-addons/raster/r.sun_horizon/r.sun2/main.c test
____________________________________________
Threshold grass key metrics values at Wed Aug 26 16:34:43 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
