[GRASS-QA] GRASS QA: neteler |gisdefs.h strings.c main.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Aug 26 20:02:54 EDT 2009
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/include/gisdefs.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/lib/gis/strings.c
          Function
G_chop(Begins at: 229, Ends at:252)
              |          New Metrics           |Old Metrics|
Complexity:   |       6 |     * |      WARNING |         6 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      24 |       |           OK |        24 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
G_squeeze(Begins at: 340, Ends at:361)
Complexity:   |       7 |       |           OK |         7 |
ParamNBR:     |       1 |     * |      WARNING |         1 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      22 |       |           OK |        22 |
G_store(Begins at: 79, Ends at:87)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |       9 |       |           OK |         9 |
G_str_replace(Begins at: 127, Ends at:191)
Complexity:   |      11 |       |           OK |        11 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      14 |       |           OK |        14 |
LOC:          |      65 |       |           OK |        65 |
G_str_to_lower(Begins at: 277, Ends at:288)
Complexity:   |       3 |     * |      WARNING |         3 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      12 |       |           OK |        12 |
G_str_to_sql(Begins at: 297, Ends at:326)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      30 |       |           OK |        30 |
Conclusion:   | this function is a            OK           |
metrics are OK
G_str_to_upper(Begins at: 259, Ends at:270)
Complexity:   |       3 |       |           OK |         3 |
G_strcasecmp(Begins at: 41, Ends at:66)
Complexity:   |      10 |       |           OK |        10 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      26 |       |           OK |        26 |
metrics are OK
G_strchg(Begins at: 98, Ends at:108)
ParamNBR:     |       3 |       |           OK |         3 |
LOC:          |      11 |       |           OK |        11 |
metrics are OK
G_strip(Begins at: 200, Ends at:217)
LOC:          |      18 |       |           OK |        18 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/vector/v.in.ogr/main.c
          Function
main(Begins at: 47, Ends at:1133)
Complexity:   |     115 |   *** |      MONSTER |       115 |
CalledNBR:    |     422 |   *** |      MONSTER |       422 |
LOC:          |    1087 |   *** |      MONSTER |      1087 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Wed Aug 26 19:41:24 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
