[GRASS-QA] GRASS QA: hamish |trim_dec.c | no clones | 0 monsters |0
	warnings
    soccerlab.info at gmail.com
    Wed Aug 26 21:00:19 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/gis/trim_dec.c
          Function
G_trim_decimal(Begins at: 29, Ends at:45)
              |          New Metrics           |Old Metrics|
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      17 |       |           OK |        17 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Aug 26 20:38:47 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
