[GRASS-QA] GRASS QA: martinl |vector.h cats.c line.c list.c | 14
	clones | 0 monsters |0 warnings
    soccerlab.info at gmail.com
    Wed Aug 26 21:14:52 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/include/vector.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/lib/vector/Vlib/cats.c
          Function
Vect__new_cats_struct(Begins at: 58, Ends at:72)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       0 |       |           OK |         0 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      15 |       |           OK |        15 |
Conclusion:   | this function is a            OK           |
metrics are OK
Vect_array_to_cat_list(Begins at: 401, Ends at:430)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       3 |       |           OK |         3 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      30 |       |           OK |        30 |
metrics are OK
Vect_cat_del(Begins at: 190, Ends at:214)
ParamNBR:     |       2 |     * |      WARNING |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      25 |       |           OK |        25 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Vect_cat_get(Begins at: 157, Ends at:179)
LOC:          |      23 |       |           OK |        23 |
metrics are OK
Vect_cat_in_array(Begins at: 462, Ends at:473)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
LOC:          |      12 |       |           OK |        12 |
Vect_cat_in_cat_list(Begins at: 441, Ends at:450)
LOC:          |      10 |       |           OK |        10 |
Vect_cat_set(Begins at: 106, Ends at:143)
Complexity:   |       6 |       |           OK |         6 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      38 |       |           OK |        38 |
metrics are OK
Vect_destroy_cat_list(Begins at: 300, Ends at:311)
Complexity:   |       3 |     * |      WARNING |         3 |
ParamNBR:     |       1 |     * |      WARNING |         1 |
 at least 2 values are close to an outlier please consider revising code!
Vect_destroy_cats_struct(Begins at: 81, Ends at:92)
ParamNBR:     |       1 |       |           OK |         1 |
metrics are OK
Vect_field_cat_del(Begins at: 226, Ends at:249)
LOC:          |      24 |       |           OK |        24 |
metrics are OK
Vect_new_cat_list(Begins at: 274, Ends at:290)
ParamNBR:     |       0 |     * |      WARNING |         0 |
LOC:          |      17 |       |           OK |        17 |
Vect_new_cats_struct(Begins at: 40, Ends at:48)
LOC:          |       9 |       |           OK |         9 |
metrics are OK
Vect_reset_cats(Begins at: 261, Ends at:266)
Complexity:   |       1 |       |           OK |         1 |
LOC:          |       6 |       |           OK |         6 |
metrics are OK
Vect_str_to_cat_list(Begins at: 324, Ends at:390)
Complexity:   |       9 |       |           OK |         9 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      18 |       |           OK |        18 |
LOC:          |      67 |       |           OK |        67 |
metrics are OK
cmp(Begins at: 475, Ends at:485)
CalledNBR:    |       0 |     * |      WARNING |         0 |
LOC:          |      11 |     * |      WARNING |        11 |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
This file has 12 potentially cloned functions:
  cmp  cmpcatkey  cmp  cmp  fcmp  dcmp  dcmp  cmp_exist  cmp  srch  srch_cat
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/cats.c clones of cmp are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_client/copy_tab.c  cmp
          /var/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_client/select.c  cmp
          /var/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_client/select.c  cmpcatkey
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/array.c  cmp
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.coin/make_coin.c  cmp
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.mapcalc/xmedian.c  fcmp
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.mapcalc/xmedian.c  dcmp
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.mapcalc/xmode.c  dcmp
          /var/project-manager/grass/grassSVN/grass/trunk/vector/v.distance/main.c  cmp_exist
          /var/project-manager/grass/grassSVN/grass/trunk/vector/v.extract/extract.c  cmp
          /var/project-manager/grass/grassSVN/grass/trunk/vector/v.to.db/update.c  srch
          /var/project-manager/grass/grassSVN/grass/trunk/vector/v.what.rast/main.c  srch_cat
          File :grass/trunk/lib/vector/Vlib/line.c
          Function
Vect__new_line_struct(Begins at: 65, Ends at:79)
metrics are OK
Vect_append_point(Begins at: 166, Ends at:179)
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      14 |       |           OK |        14 |
Vect_append_points(Begins at: 309, Ends at:340)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      32 |       |           OK |        32 |
Vect_copy_pnts_to_xyz(Begins at: 356, Ends at:371)
ParamNBR:     |       5 |     * |      WARNING |         5 |
LOC:          |      16 |       |           OK |        16 |
Vect_copy_xyz_to_pnts(Begins at: 112, Ends at:132)
LOC:          |      21 |       |           OK |        21 |
Vect_destroy_line_struct(Begins at: 88, Ends at:100)
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      13 |       |           OK |        13 |
metrics are OK
Vect_get_line_cat(Begins at: 812, Ends at:827)
Vect_line_box(Begins at: 768, Ends at:772)
LOC:          |       5 |       |           OK |         5 |
metrics are OK
Vect_line_delete_point(Begins at: 225, Ends at:244)
LOC:          |      20 |       |           OK |        20 |
metrics are OK
Vect_line_distance(Begins at: 627, Ends at:728)
Complexity:   |      13 |    ** | BABY-MONSTER |        13 |
ParamNBR:     |      11 |   *** |      MONSTER |        11 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |     102 |    ** | BABY-MONSTER |       102 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Vect_line_geodesic_length(Begins at: 580, Ends at:606)
LOC:          |      27 |       |           OK |        27 |
metrics are OK
Vect_line_insert_point(Begins at: 191, Ends at:215)
Vect_line_length(Begins at: 552, Ends at:568)
metrics are OK
Vect_line_prune(Begins at: 253, Ends at:273)
metrics are OK
Vect_line_prune_thresh(Begins at: 283, Ends at:293)
LOC:          |      11 |       |           OK |        11 |
metrics are OK
Vect_line_reverse(Begins at: 781, Ends at:800)
metrics are OK
Vect_line_segment(Begins at: 494, Ends at:541)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      48 |     * |      WARNING |        48 |
 at least 4 values are close to an outlier please consider revising code!
Vect_new_line_struct(Begins at: 55, Ends at:63)
metrics are OK
Vect_point_on_line(Begins at: 390, Ends at:475)
Complexity:   |      12 |     * |      WARNING |        12 |
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |      12 |     * |      WARNING |        12 |
LOC:          |      86 |     * |      WARNING |        86 |
Conclusion:   | this function is a  BABY-MONSTER           |
Vect_points_distance(Begins at: 742, Ends at:758)
Vect_reset_line(Begins at: 146, Ends at:151)
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/lib/vector/Vlib/list.c
          Function
Vect_destroy_list(Begins at: 74, Ends at:85)
metrics are OK
Vect_list_append(Begins at: 96, Ends at:119)
metrics are OK
Vect_list_append_list(Begins at: 130, Ends at:141)
metrics are OK
Vect_list_delete(Begins at: 152, Ends at:170)
LOC:          |      19 |       |           OK |        19 |
metrics are OK
Vect_list_delete_list(Begins at: 181, Ends at:192)
metrics are OK
Vect_new_list(Begins at: 34, Ends at:47)
metrics are OK
Vect_reset_list(Begins at: 59, Ends at:64)
metrics are OK
Vect_val_in_list(Begins at: 203, Ends at:216)
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/list.c clones of Vect_list_append_list are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/list.c  Vect_list_delete_list
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/list.c clones of Vect_list_delete_list are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/list.c  Vect_list_append_list
____________________________________________
Threshold grass key metrics values at Wed Aug 26 20:53:20 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
