[GRASS-QA] GRASS QA: glynn |get_proj.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Wed Aug 26 21:29:20 EDT 2009
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/proj/get_proj.c
Function
GPJ_get_equivalent_latlong(Begins at: 350, Ends at:359)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 10 | | OK | 10 |
Conclusion: | this function is a OK |
metrics are OK
alloc_options(Begins at: 244, Ends at:252)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 9 | | OK | 9 |
metrics are OK
pj_get_kv(Begins at: 59, Ends at:242)
Complexity: | 25 | *** | MONSTER | 25 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 75 | *** | MONSTER | 75 |
LOC: | 184 | *** | MONSTER | 184 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
pj_get_string(Begins at: 254, Ends at:332)
Complexity: | 11 | * | WARNING | 11 |
CalledNBR: | 30 | ** | BABY-MONSTER | 30 |
LOC: | 79 | * | WARNING | 79 |
Conclusion: | this function is a BABY-MONSTER |
pj_print_proj_params(Begins at: 394, Ends at:425)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 32 | | OK | 32 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
set_proj_lib(Begins at: 364, Ends at:381)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 18 | | OK | 18 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Aug 26 21:07:48 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
