[GRASS-QA] GRASS QA: hamish |get_proj.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sat Aug 29 09:42:39 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/proj/get_proj.c
          Function
GPJ_get_equivalent_latlong(Begins at: 350, Ends at:359)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      10 |       |           OK |        10 |
Conclusion:   | this function is a            OK           |
metrics are OK
alloc_options(Begins at: 244, Ends at:252)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |       9 |       |           OK |         9 |
metrics are OK
pj_get_kv(Begins at: 59, Ends at:242)
Complexity:   |      25 |   *** |      MONSTER |        25 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      75 |   *** |      MONSTER |        75 |
LOC:          |     184 |   *** |      MONSTER |       184 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
pj_get_string(Begins at: 254, Ends at:332)
Complexity:   |      11 |     * |      WARNING |        11 |
CalledNBR:    |      30 |    ** | BABY-MONSTER |        30 |
LOC:          |      79 |     * |      WARNING |        79 |
Conclusion:   | this function is a  BABY-MONSTER           |
pj_print_proj_params(Begins at: 394, Ends at:425)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |      12 |     * |      WARNING |        12 |
LOC:          |      32 |       |           OK |        32 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
set_proj_lib(Begins at: 364, Ends at:381)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      18 |       |           OK |        18 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Sat Aug 29 09:20:00 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
