[GRASS-QA] GRASS QA: martinl |driver.cpp driver.h | no clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Mon Aug 31 04:05:30 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp
Class
DisplayDriver(Begins at: -9999, Ends at:-9999)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 145 | 479 | 0 | 528 |
|OLD Metrics | 1 | 0 | 145 | 479 | 0 | 528 |
Method
Cell2Pixel(Begins at: 697, Ends at:720)
| New Metrics |Old Metrics|
Complexity: | 4 | | OK | 4 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 24 | | OK | 24 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
CloseMap(Begins at: 601, Ends at:619)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 0 | | OK | 0 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 19 | | OK | 19 |
Conclusion: | this function is a OK |
metrics are OK
DisplayDriver(Begins at: 32, Ends at:52)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 21 | | OK | 21 |
metrics are OK
DistanceInPixels(Begins at: 729, Ends at:736)
CalledNBR: | 1 | | OK | 1 |
LOC: | 8 | | OK | 8 |
metrics are OK
DrawArea(Begins at: 243, Ends at:260)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 18 | | OK | 18 |
metrics are OK
DrawArrow(Begins at: 1492, Ends at:1510)
DrawCross(Begins at: 787, Ends at:795)
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 9 | | OK | 9 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
DrawDirectionArrow(Begins at: 1411, Ends at:1480)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 14 | * | WARNING | 14 |
LOC: | 70 | * | WARNING | 70 |
at least 3 values are close to an outlier please consider revising code!
DrawLine(Begins at: 270, Ends at:432)
Complexity: | 25 | *** | MONSTER | 25 |
CalledNBR: | 45 | *** | MONSTER | 45 |
LOC: | 163 | *** | MONSTER | 163 |
Conclusion: | this function is a MONSTER |
DrawLineNodes(Begins at: 508, Ends at:590)
Complexity: | 11 | * | WARNING | 11 |
CalledNBR: | 17 | * | WARNING | 17 |
LOC: | 83 | * | WARNING | 83 |
at least 4 values are close to an outlier please consider revising code!
DrawLineVerteces(Begins at: 444, Ends at:498)
CalledNBR: | 19 | * | WARNING | 19 |
LOC: | 55 | * | WARNING | 55 |
DrawMap(Begins at: 95, Ends at:233)
Complexity: | 17 | ** | BABY-MONSTER | 17 |
CalledNBR: | 39 | *** | MONSTER | 39 |
LOC: | 139 | ** | BABY-MONSTER | 139 |
DrawSelected(Begins at: 1399, Ends at:1404)
LOC: | 6 | | OK | 6 |
metrics are OK
GetDuplicates(Begins at: 1082, Ends at:1124)
Complexity: | 7 | * | WARNING | 7 |
LOC: | 43 | * | WARNING | 43 |
GetMapBoundingBox(Begins at: 1357, Ends at:1377)
CalledNBR: | 7 | | OK | 7 |
metrics are OK
GetSelected(Begins at: 1055, Ends at:1075)
metrics are OK
GetSelectedVertex(Begins at: 1204, Ends at:1277)
Complexity: | 8 | * | WARNING | 8 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 74 | * | WARNING | 74 |
IsDuplicated(Begins at: 1134, Ends at:1140)
LOC: | 7 | | OK | 7 |
metrics are OK
IsSelected(Begins at: 1039, Ends at:1045)
metrics are OK
ListToVector(Begins at: 1314, Ends at:1326)
LOC: | 13 | | OK | 13 |
metrics are OK
OpenMap(Begins at: 630, Ends at:657)
LOC: | 28 | | OK | 28 |
PrintIds(Begins at: 881, Ends at:922)
LOC: | 42 | * | WARNING | 42 |
ReloadMap(Begins at: 670, Ends at:684)
CalledNBR: | 5 | | OK | 5 |
LOC: | 15 | | OK | 15 |
metrics are OK
ResetTopology(Begins at: 1284, Ends at:1305)
LOC: | 22 | | OK | 22 |
metrics are OK
SelectLineByPoint(Begins at: 994, Ends at:1029)
CalledNBR: | 9 | | OK | 9 |
LOC: | 36 | | OK | 36 |
SelectLinesByBox(Begins at: 937, Ends at:979)
ParamNBR: | 7 | ** | BABY-MONSTER | 7 |
CalledNBR: | 13 | * | WARNING | 13 |
SetDevice(Begins at: 82, Ends at:87)
metrics are OK
SetRegion(Begins at: 747, Ends at:774)
ParamNBR: | 10 | *** | MONSTER | 10 |
SetSelected(Begins at: 1149, Ends at:1159)
LOC: | 11 | | OK | 11 |
metrics are OK
UnSelect(Begins at: 1168, Ends at:1189)
Complexity: | 5 | | OK | 5 |
metrics are OK
UpdateSettings(Begins at: 806, Ends at:870)
ParamNBR: | 30 | *** | MONSTER | 30 |
LOC: | 65 | * | WARNING | 65 |
VectorToList(Begins at: 1337, Ends at:1350)
ParamNBR: | 2 | | OK | 2 |
LOC: | 14 | | OK | 14 |
metrics are OK
~DisplayDriver(Begins at: 63, Ends at:73)
metrics are OK
Function
print_error(Begins at: 1387, Ends at:1392)
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h
Class
DisplayDriver(Begins at: 32, Ends at:216)
|NEW Metrics | 1 | 0 | 0 | 33 | 0 | 528 |
|OLD Metrics | 1 | 0 | 0 | 33 | 0 | 528 |
Class
_region(Begins at: 69, Ends at:83)
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
_settings(Begins at: 90, Ends at:115)
Class
_topology(Begins at: 117, Ends at:135)
Class
symbol(Begins at: 85, Ends at:88)
Clone analysis:
____________________________________________
Threshold grass key metrics values at Mon Aug 31 03:41:59 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
