[GRASS-QA] GRASS QA: neteler |gsd_img_mpeg.c | 7 clones | 0 monsters
|0 warnings
soccerlab.info at gmail.com
Tue Feb 3 11:22:51 EST 2009
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/ogsf/gsd_img_mpeg.c
Function
add_video_stream(Begins at: 55, Ends at:103)
| New Metrics |Old Metrics|
Complexity: | 5 | | OK | 5 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 49 | * | WARNING | 49 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
alloc_picture(Begins at: 115, Ends at:138)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 24 | | OK | 24 |
at least 1 values are close to an outlier please consider revising code!
close_video(Begins at: 264, Ends at:274)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 2 | | OK | 2 |
LOC: | 11 | | OK | 11 |
Conclusion: | this function is a OK |
metrics are OK
gsd_close_mpeg(Begins at: 421, Ends at:450)
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 30 | | OK | 30 |
metrics are OK
gsd_init_mpeg(Begins at: 286, Ends at:365)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 27 | ** | BABY-MONSTER | 27 |
LOC: | 80 | * | WARNING | 80 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
gsd_write_mpegframe(Begins at: 374, Ends at:414)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 41 | | OK | 41 |
metrics are OK
open_video(Begins at: 146, Ends at:196)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 51 | * | WARNING | 51 |
at least 3 values are close to an outlier please consider revising code!
write_video_frame(Begins at: 204, Ends at:256)
CalledNBR: | 9 | | OK | 9 |
LOC: | 53 | * | WARNING | 53 |
Clone analysis:
This file has 7 potentially cloned functions:
alloc_picture close_video gsd_close_mpeg gsd_init_mpeg gsd_write_mpegframe open_video
In /var/project-manager/grass/grassSVN/grass/trunk/lib/ogsf/gsd_img_mpeg.c clones of add_video_stream are:
/tmp/grassSVN/grass/trunk/lib/ogsf/gsd_img_mpeg.c add_video_stream
In /var/project-manager/grass/grassSVN/grass/trunk/lib/ogsf/gsd_img_mpeg.c clones of alloc_picture are:
/tmp/grassSVN/grass/trunk/lib/ogsf/gsd_img_mpeg.c alloc_picture
In /var/project-manager/grass/grassSVN/grass/trunk/lib/ogsf/gsd_img_mpeg.c clones of close_video are:
/tmp/grassSVN/grass/trunk/lib/ogsf/gsd_img_mpeg.c close_video
In /var/project-manager/grass/grassSVN/grass/trunk/lib/ogsf/gsd_img_mpeg.c clones of gsd_close_mpeg are:
/tmp/grassSVN/grass/trunk/lib/ogsf/gsd_img_mpeg.c gsd_close_mpeg
In /var/project-manager/grass/grassSVN/grass/trunk/lib/ogsf/gsd_img_mpeg.c clones of gsd_init_mpeg are:
/tmp/grassSVN/grass/trunk/lib/ogsf/gsd_img_mpeg.c gsd_init_mpeg
In /var/project-manager/grass/grassSVN/grass/trunk/lib/ogsf/gsd_img_mpeg.c clones of gsd_write_mpegframe are:
/tmp/grassSVN/grass/trunk/lib/ogsf/gsd_img_mpeg.c gsd_write_mpegframe
In /var/project-manager/grass/grassSVN/grass/trunk/lib/ogsf/gsd_img_mpeg.c clones of open_video are:
/tmp/grassSVN/grass/trunk/lib/ogsf/gsd_img_mpeg.c open_video
____________________________________________
Threshold grass key metrics values at Tue Feb 03 11:46:25 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
