[GRASS-QA] GRASS QA: martinl |btree.c main.c | 6 clones | 0 monsters
|0 warnings
soccerlab.info at gmail.com
Tue Feb 3 11:42:57 EST 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/raster/r.cost/btree.c
Function
check(Begins at: 410, Ends at:445)
| New Metrics |Old Metrics|
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 18 | * | WARNING | 18 |
LOC: | 36 | | OK | 36 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
check_all(Begins at: 400, Ends at:408)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 9 | | OK | 9 |
Conclusion: | this function is a OK |
metrics are OK
delete(Begins at: 182, Ends at:367)
Complexity: | 25 | *** | MONSTER | 25 |
CalledNBR: | 19 | * | WARNING | 19 |
LOC: | 186 | *** | MONSTER | 186 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
do_quit(Begins at: 144, Ends at:150)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 7 | | OK | 6 |
at least 1 values are close to an outlier please consider revising code!
find(Begins at: 107, Ends at:142)
Complexity: | 7 | * | WARNING | 7 |
get_lowest(Begins at: 152, Ends at:180)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 29 | | OK | 29 |
metrics are OK
insert(Begins at: 51, Ends at:104)
Complexity: | 9 | * | WARNING | 9 |
LOC: | 54 | * | WARNING | 53 |
at least 3 values are close to an outlier please consider revising code!
show(Begins at: 380, Ends at:398)
Complexity: | 3 | | OK | 3 |
LOC: | 19 | | OK | 19 |
metrics are OK
show_all(Begins at: 369, Ends at:378)
CalledNBR: | 2 | | OK | 3 |
LOC: | 10 | | OK | 10 |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
get_lowest show F_close
In /var/project-manager/grass/grassSVN/grass/trunk/raster/r.cost/btree.c clones of check_all are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/bitmap/bitmap.c BM_destroy
In /var/project-manager/grass/grassSVN/grass/trunk/raster/r.cost/btree.c clones of get_lowest are:
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.walk/btree.c get_lowest
In /var/project-manager/grass/grassSVN/grass/trunk/raster/r.cost/btree.c clones of show are:
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.walk/btree.c show
In /var/project-manager/grass/grassSVN/grass/trunk/raster/r.cost/btree.c clones of show_all are:
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.digit/open.c F_close
File :grass/trunk/raster/r.cost/main.c
Class
variables(Begins at: 70, Ends at:78)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Function
main(Begins at: 86, Ends at:1028)
Complexity: | 137 | *** | MONSTER | 138 |
CalledNBR: | 276 | *** | MONSTER | 283 |
LOC: | 943 | *** | MONSTER | 947 |
process_answers(Begins at: 1030, Ends at:1080)
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 51 | * | WARNING | 51 |
at least 4 values are close to an outlier please consider revising code!
time_to_stop(Begins at: 1082, Ends at:1102)
Complexity: | 6 | * | WARNING | 6 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 21 | | OK | 21 |
Clone analysis:
This file has 2 potentially cloned functions:
time_to_stop
In /var/project-manager/grass/grassSVN/grass/trunk/raster/r.cost/main.c clones of process_answers are:
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.walk/main.c process_answers
In /var/project-manager/grass/grassSVN/grass/trunk/raster/r.cost/main.c clones of time_to_stop are:
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.walk/main.c time_to_stop
____________________________________________
Threshold grass key metrics values at Tue Feb 03 12:06:31 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
