[GRASS-QA] GRASS QA: martinl |main.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Tue Feb 3 11:50:52 EST 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/raster/r.drain/main.c
Class
point(Begins at: 60, Ends at:66)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Function
drain(Begins at: 460, Ends at:517)
| New Metrics |Old Metrics|
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 58 | * | WARNING | 58 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
main(Begins at: 68, Ends at:458)
Complexity: | 41 | *** | MONSTER | 41 |
ParamNBR: | 8 | ** | BABY-MONSTER | 8 |
CalledNBR: | 133 | *** | MONSTER | 133 |
LOC: | 391 | *** | MONSTER | 391 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Feb 03 12:14:27 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
