[GRASS-QA] GRASS QA: kyngchaos |render.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Tue Feb 3 12:35:31 EST 2009
Hello kyngchaos,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/lib/nviz/render.c
Function
Nviz_create_render_window(Begins at: 96, Ends at:179)
| New Metrics |Old Metrics|
Complexity: | 4 | | OK | 4 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 25 | ** | BABY-MONSTER | 25 |
LOC: | 84 | * | WARNING | 84 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Nviz_destroy_render_window(Begins at: 67, Ends at:84)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 18 | | OK | 18 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Nviz_init_render_window(Begins at: 43, Ends at:60)
CalledNBR: | 3 | | OK | 3 |
Conclusion: | this function is a OK |
metrics are OK
Nviz_make_current_render_window(Begins at: 189, Ends at:213)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 25 | | OK | 25 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Feb 03 12:59:05 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
