[GRASS-QA] GRASS QA: martinl |env.c | 3 clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Tue Feb 3 14:40:21 EST 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/gis/env.c
Function
G__create_alt_env(Begins at: 537, Ends at:552)
| New Metrics |Old Metrics|
Complexity: | 3 | | OK | 3 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 16 | | OK | 16 |
Conclusion: | this function is a OK |
metrics are OK
G__env_name(Begins at: 476, Ends at:486)
Complexity: | 4 | | OK | 4 |
LOC: | 11 | | OK | 11 |
metrics are OK
G__get_gisrc_file(Begins at: 525, Ends at:528)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 4 | | OK | 4 |
metrics are OK
G__getenv(Begins at: 312, Ends at:320)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 9 | | OK | 9 |
metrics are OK
G__getenv2(Begins at: 331, Ends at:339)
ParamNBR: | 2 | | OK | 2 |
metrics are OK
G__read_env(Begins at: 495, Ends at:500)
ParamNBR: | 1 | * | WARNING | 1 |
LOC: | 6 | | OK | 6 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
G__set_gisrc_file(Begins at: 509, Ends at:516)
LOC: | 8 | | OK | 8 |
metrics are OK
G__setenv(Begins at: 388, Ends at:393)
CalledNBR: | 2 | | OK | 2 |
metrics are OK
G__setenv2(Begins at: 404, Ends at:409)
ParamNBR: | 3 | | OK | 3 |
metrics are OK
G__switch_env(Begins at: 561, Ends at:576)
metrics are OK
G__write_env(Begins at: 454, Ends at:460)
LOC: | 7 | | OK | 7 |
metrics are OK
G_get_gisrc_mode(Begins at: 71, Ends at:74)
metrics are OK
G_getenv(Begins at: 267, Ends at:276)
CalledNBR: | 3 | | OK | 3 |
LOC: | 10 | | OK | 10 |
metrics are OK
G_getenv2(Begins at: 293, Ends at:302)
metrics are OK
G_set_gisrc_mode(Begins at: 59, Ends at:62)
metrics are OK
G_setenv(Begins at: 352, Ends at:358)
metrics are OK
G_setenv2(Begins at: 372, Ends at:378)
ParamNBR: | 3 | * | WARNING | 3 |
G_unsetenv(Begins at: 420, Ends at:427)
metrics are OK
G_unsetenv2(Begins at: 438, Ends at:445)
metrics are OK
get_env(Begins at: 182, Ends at:193)
LOC: | 12 | | OK | 12 |
metrics are OK
open_env(Begins at: 233, Ends at:256)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 24 | | OK | 24 |
metrics are OK
read_env(Begins at: 76, Ends at:110)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 35 | | OK | 35 |
set_env(Begins at: 112, Ends at:165)
Complexity: | 8 | * | WARNING | 8 |
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 54 | * | WARNING | 54 |
at least 4 values are close to an outlier please consider revising code!
unset_env(Begins at: 167, Ends at:180)
LOC: | 14 | | OK | 14 |
metrics are OK
write_env(Begins at: 195, Ends at:207)
LOC: | 13 | | OK | 13 |
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
open_output_map open_output_map
In /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/env.c clones of G__switch_env are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/gis/mapset_nme.c G__switch_search_path
In /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/env.c clones of G_getenv2 are:
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.mapcalc/map.c open_output_map
/var/project-manager/grass/grassSVN/grass/trunk/raster3d/r3.to.rast/main.c open_output_map
____________________________________________
Threshold grass key metrics values at Tue Feb 03 15:03:56 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
