[GRASS-QA] GRASS QA: martinl |arcs.c args.c connect.c main.c ...| no
clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Tue Feb 3 14:58:19 EST 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/vector/v.net/arcs.c
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/vector/v.net/args.c
File :grass/trunk/vector/v.net/connect.c
Function
connect_arcs(Begins at: 37, Ends at:119)
| New Metrics |Old Metrics|
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 30 | ** | BABY-MONSTER | 30 |
LOC: | 83 | * | WARNING | 83 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/vector/v.net/main.c
Function
main(Begins at: 28, Ends at:212)
Complexity: | 20 | ** | BABY-MONSTER | 20 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 78 | *** | MONSTER | 78 |
LOC: | 185 | *** | MONSTER | 185 |
Conclusion: | this function is a MONSTER |
Clone analysis:
File :grass/trunk/vector/v.net/nodes.c
Function
nodes(Begins at: 24, Ends at:92)
Complexity: | 11 | * | WARNING | 11 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 69 | * | WARNING | 69 |
Conclusion: | this function is a WARNING |
at least 4 values are close to an outlier please consider revising code!
Clone analysis:
File :grass/trunk/vector/v.net/proto.h
File :grass/trunk/vector/v.net/report.c
Function
report(Begins at: 24, Ends at:127)
Complexity: | 21 | *** | MONSTER | 21 |
CalledNBR: | 32 | ** | BABY-MONSTER | 32 |
LOC: | 104 | ** | BABY-MONSTER | 104 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Feb 03 15:21:55 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
