[GRASS-QA] GRASS QA: mmetz |main.c init_vars.c init_vars.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Feb 3 15:03:14 EST 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/raster/r.watershed/front/main.c
          Function
main(Begins at: 25, Ends at:427)
              |          New Metrics           |Old Metrics|
Complexity:   |      33 |   *** |      MONSTER |        33 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     150 |   *** |      MONSTER |       150 |
LOC:          |     403 |   *** |      MONSTER |       403 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
write_hist(Begins at: 430, Ends at:447)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      18 |       |           OK |        18 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/raster/r.watershed/ram/init_vars.c
          Function
init_vars(Begins at: 8, Ends at:412)
Complexity:   |     102 |       |           OK |       102 |
CalledNBR:    |     176 |       |           OK |       176 |
LOC:          |     405 |       |           OK |       405 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.watershed/seg/init_vars.c
          Function
init_vars(Begins at: 9, Ends at:517)
Complexity:   |     113 |       |           OK |       113 |
CalledNBR:    |     178 |       |           OK |       178 |
LOC:          |     509 |       |           OK |       509 |
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Feb 03 15:26:50 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
