[GRASS-QA] GRASS QA: glynn |main.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Wed Feb 4 10:53:03 EST 2009
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/visualization/ximgview/main.c
Function
create_window(Begins at: 57, Ends at:100)
| New Metrics |Old Metrics|
Complexity: | 3 | | OK | 3 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 20 | * | WARNING | 20 |
LOC: | 44 | * | WARNING | 44 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
draw(Begins at: 102, Ends at:123)
CalledNBR: | 4 | | OK | 4 |
LOC: | 22 | | OK | 22 |
Conclusion: | this function is a OK |
metrics are OK
dummy_handler(Begins at: 137, Ends at:139)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 3 | | OK | 3 |
metrics are OK
get_2(Begins at: 188, Ends at:195)
CalledNBR: | 0 | * | WARNING | 0 |
LOC: | 8 | * | WARNING | 8 |
get_4(Begins at: 197, Ends at:204)
Complexity: | 1 | * | WARNING | 1 |
at least 3 values are close to an outlier please consider revising code!
main(Begins at: 276, Ends at:322)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 15 | * | WARNING | 15 |
LOC: | 47 | | OK | 47 |
at least 1 values are close to an outlier please consider revising code!
main_loop(Begins at: 141, Ends at:186)
Complexity: | 8 | * | WARNING | 8 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 46 | | OK | 46 |
map_file(Begins at: 248, Ends at:274)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 15 | | OK | 15 |
LOC: | 27 | | OK | 27 |
metrics are OK
read_bmp_header(Begins at: 206, Ends at:246)
Complexity: | 9 | | OK | 9 |
CalledNBR: | 14 | | OK | 14 |
LOC: | 41 | | OK | 41 |
metrics are OK
redraw(Begins at: 125, Ends at:135)
CalledNBR: | 3 | | OK | 3 |
LOC: | 11 | | OK | 11 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Feb 04 11:16:50 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
