[GRASS-QA] GRASS QA: neteler |driver.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Feb 4 11:37:03 EST 2009
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/vector/v.digit/driver.c
          Function
driver_close(Begins at: 118, Ends at:121)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
Conclusion:   | this function is a            OK           |
metrics are OK
driver_cont_abs(Begins at: 30, Ends at:41)
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      12 |       |           OK |        12 |
metrics are OK
driver_line_width(Begins at: 16, Ends at:19)
metrics are OK
driver_move_abs(Begins at: 23, Ends at:28)
LOC:          |       6 |       |           OK |         6 |
metrics are OK
driver_open(Begins at: 96, Ends at:116)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |      18 |     * |      WARNING |        18 |
LOC:          |      21 |       |           OK |        21 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
driver_plot_icon(Begins at: 43, Ends at:55)
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      13 |       |           OK |        13 |
driver_refresh(Begins at: 88, Ends at:94)
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |       7 |       |           OK |         7 |
metrics are OK
driver_rgb_color(Begins at: 11, Ends at:14)
CalledNBR:    |       1 |       |           OK |         1 |
get_window(Begins at: 57, Ends at:69)
ParamNBR:     |       4 |     * |      WARNING |         4 |
setup(Begins at: 71, Ends at:86)
Complexity:   |       3 |       |           OK |         3 |
LOC:          |      16 |       |           OK |        16 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Feb 04 12:00:50 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
