[GRASS-QA] GRASS QA: kyngchaos |bilinear_f.c cubic_f.c main.c r.proj.h | 1 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Feb 6 11:46:21 EST 2009
Hello kyngchaos,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/raster/r.proj.seg/bilinear_f.c
The system don't find class, method and function
 in this file during analysis!
          File :grass/branches/develbranch_6/raster/r.proj.seg/cubic_f.c
          File :grass/branches/develbranch_6/raster/r.proj.seg/main.c
          Function
main(Begins at: 75, Ends at:466)
              |          New Metrics           |Old Metrics|
Complexity:   |      32 |   *** |      MONSTER |        32 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     164 |   *** |      MONSTER |       164 |
LOC:          |     392 |   *** |      MONSTER |       392 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
make_ipol_list(Begins at: 468, Ends at:487)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      20 |       |           OK |        20 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.proj.seg/main.c clones of make_ipol_list are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.proj/main.c  make_ipol_list
          File :grass/branches/develbranch_6/raster/r.proj.seg/r.proj.h
          Class
cache(Begins at: 17, Ends at:25)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
menu(Begins at: 30, Ends at:35)
          Function
BKIDX(Begins at: 62, Ends at:65)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
BKPTR(Begins at: 67, Ends at:70)
CalledNBR:    |       1 |       |           OK |         1 |
BLOCK(Begins at: 72, Ends at:75)
CPTR(Begins at: 77, Ends at:80)
CalledNBR:    |       5 |       |           OK |         5 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Fri Feb 06 12:10:34 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
