[GRASS-QA] GRASS QA: glynn |addpts.c add_in.c bseg_close.c bseg_get.c ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Feb 24 09:39:19 EST 2009
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/raster/r.surf.contour/addpts.c
          Function
addpts(Begins at: 3, Ends at:24)
              |          New Metrics           |Old Metrics|
Complexity:   |       9 |     * |      WARNING |         9 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      22 |       |           OK |        22 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
addpts_slow(Begins at: 3, Ends at:29)
LOC:          |      27 |       |           OK |        27 |
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/raster/r.surf.contour/add_in.c
          Function
add_in(Begins at: 3, Ends at:28)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      26 |       |           OK |        26 |
add_in_slow(Begins at: 3, Ends at:28)
Clone analysis:
          File :grass/trunk/raster/r.surf.contour/bseg_close.c
          Function
bseg_close(Begins at: 5, Ends at:19)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      15 |       |           OK |        15 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.surf.contour/bseg_get.c
          Function
bseg_get(Begins at: 4, Ends at:18)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       3 |       |           OK |         3 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
          File :grass/trunk/raster/r.surf.contour/bseg_open.c
          Function
bseg_open(Begins at: 8, Ends at:60)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      53 |     * |      WARNING |        53 |
 at least 4 values are close to an outlier please consider revising code!
Clone analysis:
          File :grass/trunk/raster/r.surf.contour/bseg_put.c
          Function
bseg_put(Begins at: 4, Ends at:28)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      25 |       |           OK |        25 |
Clone analysis:
          File :grass/trunk/raster/r.surf.contour/bseg_read.c
          Function
bseg_read_cell(Begins at: 7, Ends at:49)
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      16 |     * |      WARNING |        16 |
LOC:          |      43 |     * |      WARNING |        43 |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
          File :grass/trunk/raster/r.surf.contour/bseg_write.c
          Function
bseg_write_cellfile(Begins at: 6, Ends at:38)
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      12 |     * |      WARNING |        12 |
LOC:          |      33 |       |           OK |        33 |
Clone analysis:
          File :grass/trunk/raster/r.surf.contour/contour.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/raster/r.surf.contour/cseg.h
          File :grass/trunk/raster/r.surf.contour/cseg_close.c
          Function
cseg_close(Begins at: 5, Ends at:19)
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.surf.contour/cseg_get.c
          Function
cseg_get(Begins at: 4, Ends at:11)
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       8 |       |           OK |         8 |
Clone analysis:
          File :grass/trunk/raster/r.surf.contour/cseg_open.c
          Function
cseg_open(Begins at: 8, Ends at:60)
Clone analysis:
          File :grass/trunk/raster/r.surf.contour/cseg_put.c
          Function
cseg_put(Begins at: 4, Ends at:11)
Clone analysis:
          File :grass/trunk/raster/r.surf.contour/cseg_read.c
          Function
cseg_read_cell(Begins at: 7, Ends at:51)
CalledNBR:    |      19 |     * |      WARNING |        19 |
LOC:          |      45 |     * |      WARNING |        45 |
Clone analysis:
          File :grass/trunk/raster/r.surf.contour/cseg_write.c
          Function
cseg_write_cellfile(Begins at: 6, Ends at:36)
CalledNBR:    |      13 |     * |      WARNING |        13 |
LOC:          |      31 |       |           OK |        31 |
Clone analysis:
          File :grass/trunk/raster/r.surf.contour/find_con.c
          Function
find_con(Begins at: 4, Ends at:72)
Complexity:   |      15 |    ** | BABY-MONSTER |        15 |
CalledNBR:    |      16 |     * |      WARNING |        17 |
LOC:          |      69 |     * |      WARNING |        69 |
find_con_slow(Begins at: 4, Ends at:75)
CalledNBR:    |      17 |     * |      WARNING |        17 |
LOC:          |      72 |     * |      WARNING |        72 |
Clone analysis:
          File :grass/trunk/raster/r.surf.contour/main.c
          Function
main(Begins at: 43, Ends at:145)
Complexity:   |      14 |    ** | BABY-MONSTER |        14 |
CalledNBR:    |      44 |   *** |      MONSTER |        44 |
LOC:          |     103 |    ** | BABY-MONSTER |       103 |
Conclusion:   | this function is a       MONSTER           |
Clone analysis:
          File :grass/trunk/raster/r.surf.contour/read_cell.c
          Function
free_cell(Begins at: 33, Ends at:37)
Complexity:   |       1 |       |           OK |           |
ParamNBR:     |       1 |       |           OK |           |
CalledNBR:    |       2 |       |           OK |           |
LOC:          |       5 |       |           OK |           |
metrics are OK
read_cell(Begins at: 4, Ends at:31)
Complexity:   |       4 |       |           OK |           |
ParamNBR:     |       2 |       |           OK |           |
CalledNBR:    |      13 |     * |      WARNING |           |
LOC:          |      28 |       |           OK |           |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Feb 24 09:42:54 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
