[GRASS-QA] GRASS QA: martinl |Gs3.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Feb 24 13:33:55 EST 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/lib/ogsf/Gs3.c
          Function
Gs_build_256lookup(Begins at: 623, Ends at:671)
              |          New Metrics           |Old Metrics|
Complexity:   |       6 |     * |      WARNING |         6 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      49 |     * |      WARNING |        49 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
Gs_distance(Begins at: 84, Ends at:94)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      11 |       |           OK |        11 |
Conclusion:   | this function is a            OK           |
metrics are OK
Gs_get_cat_label(Begins at: 820, Ends at:885)
Complexity:   |       8 |     * |      WARNING |         8 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      27 |    ** | BABY-MONSTER |        27 |
LOC:          |      66 |     * |      WARNING |        66 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Gs_load_3dview(Begins at: 997, Ends at:1122)
Complexity:   |      16 |    ** | BABY-MONSTER |        16 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
LOC:          |     126 |    ** | BABY-MONSTER |       126 |
Gs_loadmap_as_bitmap(Begins at: 555, Ends at:609)
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      21 |     * |      WARNING |        21 |
LOC:          |      55 |     * |      WARNING |        55 |
 at least 4 values are close to an outlier please consider revising code!
Gs_loadmap_as_char(Begins at: 446, Ends at:534)
Complexity:   |      11 |     * |      WARNING |        11 |
CalledNBR:    |      23 |    ** | BABY-MONSTER |        23 |
LOC:          |      89 |     * |      WARNING |        89 |
Gs_loadmap_as_float(Begins at: 114, Ends at:166)
Complexity:   |       7 |     * |      WARNING |         7 |
LOC:          |      53 |     * |      WARNING |        53 |
Gs_loadmap_as_int(Begins at: 188, Ends at:239)
CalledNBR:    |      19 |     * |      WARNING |        19 |
LOC:          |      52 |     * |      WARNING |        52 |
Gs_loadmap_as_short(Begins at: 332, Ends at:418)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |      25 |    ** | BABY-MONSTER |        25 |
LOC:          |      87 |     * |      WARNING |        87 |
Gs_numtype(Begins at: 250, Ends at:310)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      61 |     * |      WARNING |        61 |
 at least 2 values are close to an outlier please consider revising code!
Gs_pack_colors(Begins at: 684, Ends at:735)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |      17 |     * |      WARNING |        17 |
Gs_pack_colors_float(Begins at: 751, Ends at:805)
Gs_save_3dview(Begins at: 899, Ends at:984)
CalledNBR:    |      12 |     * |      WARNING |        12 |
LOC:          |      86 |     * |      WARNING |        86 |
Gs_update_attrange(Begins at: 1133, Ends at:1243)
Complexity:   |      13 |    ** | BABY-MONSTER |        13 |
LOC:          |     111 |    ** | BABY-MONSTER |       111 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Feb 24 13:37:33 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
