[GRASS-QA] GRASS QA: martinl |Vect.h cats.c b2a.c | 12 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Feb 24 13:45:45 EST 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/include/Vect.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/branches/develbranch_6/lib/vector/Vlib/cats.c
          Function
Vect__new_cats_struct(Begins at: 58, Ends at:72)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       0 |       |           OK |         0 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      15 |       |           OK |        15 |
Conclusion:   | this function is a            OK           |
metrics are OK
Vect_array_to_cat_list(Begins at: 403, Ends at:432)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      30 |       |           OK |        30 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Vect_cat_del(Begins at: 191, Ends at:215)
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      25 |       |           OK |        25 |
metrics are OK
Vect_cat_get(Begins at: 158, Ends at:180)
LOC:          |      23 |       |           OK |        23 |
Vect_cat_in_array(Begins at: 464, Ends at:475)
Complexity:   |       2 |       |           OK |         2 |
LOC:          |      12 |       |           OK |        12 |
Vect_cat_in_cat_list(Begins at: 443, Ends at:452)
LOC:          |      10 |       |           OK |        10 |
metrics are OK
Vect_cat_set(Begins at: 106, Ends at:144)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      39 |       |           OK |        39 |
 at least 2 values are close to an outlier please consider revising code!
Vect_destroy_cat_list(Begins at: 301, Ends at:312)
ParamNBR:     |       1 |       |           OK |         1 |
metrics are OK
Vect_destroy_cats_struct(Begins at: 81, Ends at:92)
metrics are OK
Vect_field_cat_del(Begins at: 227, Ends at:250)
LOC:          |      24 |       |           OK |        24 |
Vect_new_cat_list(Begins at: 275, Ends at:291)
LOC:          |      17 |       |           OK |        17 |
metrics are OK
Vect_new_cats_struct(Begins at: 40, Ends at:48)
LOC:          |       9 |       |           OK |         9 |
metrics are OK
Vect_reset_cats(Begins at: 262, Ends at:267)
Complexity:   |       1 |       |           OK |         1 |
LOC:          |       6 |       |           OK |         6 |
metrics are OK
Vect_str_to_cat_list(Begins at: 325, Ends at:392)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |      18 |     * |      WARNING |        18 |
LOC:          |      68 |     * |      WARNING |        68 |
 at least 3 values are close to an outlier please consider revising code!
cmp(Begins at: 477, Ends at:487)
LOC:          |      11 |       |           OK |        11 |
metrics are OK
Clone analysis:
This file has 12 potentially cloned functions:
  cmp  cmpcatkey  cmp  cmp  fcmp  dcmp  dcmp  cmp_exist  cmp  srch  srch_cat
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/Vlib/cats.c clones of cmp are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/db/dbmi_client/copy_tab.c  cmp
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/db/dbmi_client/select.c  cmp
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/db/dbmi_client/select.c  cmpcatkey
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/Vlib/array.c  cmp
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.coin/make_coin.c  cmp
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.mapcalc/xmedian.c  fcmp
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.mapcalc/xmedian.c  dcmp
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.mapcalc/xmode.c  dcmp
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/vector/v.distance/main.c  cmp_exist
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/vector/v.extract/extract.c  cmp
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/vector/v.to.db/update.c  srch
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/vector/v.what.rast/main.c  srch_cat
          File :grass/branches/develbranch_6/vector/v.out.ascii/b2a.c
          Function
bin_to_asc(Begins at: 6, Ends at:189)
Complexity:   |      35 |   *** |      MONSTER |        35 |
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
CalledNBR:    |      46 |   *** |      MONSTER |        46 |
LOC:          |     184 |   *** |      MONSTER |       184 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Feb 24 13:49:23 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
