[GRASS-QA] GRASS QA: martinl |Vect.h cats.c b2a.c | 12 clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Tue Feb 24 14:01:36 EST 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/include/Vect.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/lib/vector/Vlib/cats.c
Function
Vect__new_cats_struct(Begins at: 58, Ends at:72)
| New Metrics |Old Metrics|
Complexity: | 3 | | OK | 3 |
ParamNBR: | 0 | | OK | 0 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 15 | | OK | 15 |
Conclusion: | this function is a OK |
metrics are OK
Vect_array_to_cat_list(Begins at: 401, Ends at:430)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 3 | | OK | 3 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 30 | | OK | 30 |
metrics are OK
Vect_cat_del(Begins at: 190, Ends at:214)
ParamNBR: | 2 | * | WARNING | 2 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 25 | | OK | 25 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Vect_cat_get(Begins at: 157, Ends at:179)
LOC: | 23 | | OK | 23 |
metrics are OK
Vect_cat_in_array(Begins at: 462, Ends at:473)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 12 | | OK | 12 |
Vect_cat_in_cat_list(Begins at: 441, Ends at:450)
LOC: | 10 | | OK | 10 |
Vect_cat_set(Begins at: 106, Ends at:143)
Complexity: | 6 | | OK | 6 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 38 | | OK | 38 |
metrics are OK
Vect_destroy_cat_list(Begins at: 300, Ends at:311)
Complexity: | 3 | * | WARNING | 3 |
ParamNBR: | 1 | * | WARNING | 1 |
at least 2 values are close to an outlier please consider revising code!
Vect_destroy_cats_struct(Begins at: 81, Ends at:92)
ParamNBR: | 1 | | OK | 1 |
metrics are OK
Vect_field_cat_del(Begins at: 226, Ends at:249)
LOC: | 24 | | OK | 24 |
metrics are OK
Vect_new_cat_list(Begins at: 274, Ends at:290)
ParamNBR: | 0 | * | WARNING | 0 |
LOC: | 17 | | OK | 17 |
Vect_new_cats_struct(Begins at: 40, Ends at:48)
LOC: | 9 | | OK | 9 |
metrics are OK
Vect_reset_cats(Begins at: 261, Ends at:266)
Complexity: | 1 | | OK | 1 |
LOC: | 6 | | OK | 6 |
metrics are OK
Vect_str_to_cat_list(Begins at: 324, Ends at:390)
Complexity: | 9 | | OK | 9 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 18 | | OK | 18 |
LOC: | 67 | | OK | 67 |
metrics are OK
cmp(Begins at: 475, Ends at:485)
CalledNBR: | 0 | * | WARNING | 0 |
LOC: | 11 | * | WARNING | 11 |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
This file has 12 potentially cloned functions:
cmp cmpcatkey cmp cmp fcmp dcmp dcmp cmp_exist cmp srch srch_cat
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/cats.c clones of cmp are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_client/copy_tab.c cmp
/var/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_client/select.c cmp
/var/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_client/select.c cmpcatkey
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/array.c cmp
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.coin/make_coin.c cmp
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.mapcalc/xmedian.c fcmp
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.mapcalc/xmedian.c dcmp
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.mapcalc/xmode.c dcmp
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.distance/main.c cmp_exist
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.extract/extract.c cmp
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.to.db/update.c srch
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.what.rast/main.c srch_cat
File :grass/trunk/vector/v.out.ascii/b2a.c
Function
bin_to_asc(Begins at: 6, Ends at:189)
Complexity: | 35 | *** | MONSTER | 35 |
ParamNBR: | 8 | ** | BABY-MONSTER | 8 |
CalledNBR: | 46 | *** | MONSTER | 46 |
LOC: | 184 | *** | MONSTER | 184 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Feb 24 14:05:14 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
