[GRASS-QA] GRASS QA: neteler |main.cpp | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Feb 24 15:05:54 EST 2009
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/imagery/i.atcorr/main.cpp
          Class
IntPair(Begins at: 202, Ends at:216)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      5 |      2 |      0 |      1 |
|OLD Metrics |      1 |      0 |      5 |      2 |      0 |      1 |
          Method
IntPair(Begins at: 207, Ends at:207)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       1 |       |           OK |         1 |
Conclusion:   | this function is a            OK           |
metrics are OK
operator<(Begins at: 209, Ends at:215)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       7 |       |           OK |         7 |
metrics are OK
          Class
Options(Begins at: 41, Ends at:60)
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
Position(Begins at: 171, Ends at:177)
|NEW Metrics |      1 |      0 |      2 |      2 |      0 |      1 |
|OLD Metrics |      1 |      0 |      2 |      2 |      0 |      1 |
          Method
Position(Begins at: 175, Ends at:175)
metrics are OK
valid(Begins at: 176, Ends at:176)
ParamNBR:     |       0 |       |           OK |         0 |
metrics are OK
          Class
ScaleRange(Begins at: 62, Ends at:66)
          Class
TICache(Begins at: 123, Ends at:153)
|NEW Metrics |      1 |      0 |      8 |      4 |      0 |      2 |
|OLD Metrics |      1 |      0 |      8 |      4 |      0 |      2 |
          Method
TICache(Begins at: 134, Ends at:134)
Complexity:   |       2 |       |           OK |         2 |
metrics are OK
add(Begins at: 147, Ends at:152)
LOC:          |       6 |       |           OK |         6 |
metrics are OK
get(Begins at: 146, Ends at:146)
metrics are OK
search(Begins at: 135, Ends at:144)
Complexity:   |       3 |       |           OK |         3 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
          Class
TIMap(Begins at: 159, Ends at:199)
|NEW Metrics |      1 |      0 |      8 |     10 |      0 |      4 |
|OLD Metrics |      1 |      0 |      8 |     10 |      0 |      4 |
          Method
TIMap(Begins at: 179, Ends at:179)
ParamNBR:     |       0 |     * |      WARNING |         0 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
add(Begins at: 193, Ends at:198)
ParamNBR:     |       3 |       |           OK |         2 |
CalledNBR:    |       1 |       |           OK |         0 |
metrics are OK
get(Begins at: 191, Ends at:191)
metrics are OK
search(Begins at: 180, Ends at:189)
ParamNBR:     |       2 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         0 |
metrics are OK
          Function
adjust_region(Begins at: 88, Ends at:97)
CalledNBR:    |       4 |       |           OK |         4 |
metrics are OK
copy_colors(Begins at: 392, Ends at:398)
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       3 |       |           OK |         3 |
define_module(Begins at: 402, Ends at:426)
LOC:          |      25 |       |           OK |        25 |
metrics are OK
define_options(Begins at: 430, Ends at:499)
CalledNBR:    |      12 |     * |      WARNING |        12 |
LOC:          |      70 |     * |      WARNING |        70 |
 at least 2 values are close to an outlier please consider revising code!
main(Begins at: 533, Ends at:619)
Complexity:   |      18 |    ** | BABY-MONSTER |        18 |
CalledNBR:    |      35 |    ** | BABY-MONSTER |        35 |
LOC:          |      87 |     * |      WARNING |        87 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
optimize_va(Begins at: 222, Ends at:242)
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      21 |       |           OK |        21 |
process_raster(Begins at: 259, Ends at:387)
Complexity:   |      23 |   *** |      MONSTER |        23 |
ParamNBR:     |       9 |   *** |      MONSTER |         9 |
CalledNBR:    |      42 |   *** |      MONSTER |        42 |
LOC:          |     129 |    ** | BABY-MONSTER |       129 |
Conclusion:   | this function is a       MONSTER           |
read_scale(Begins at: 502, Ends at:530)
LOC:          |      29 |       |           OK |        29 |
metrics are OK
round_c(Begins at: 101, Ends at:107)
metrics are OK
write_fp_to_cell(Begins at: 111, Ends at:120)
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Feb 24 15:09:32 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
