[GRASS-QA] GRASS QA: hamish |parser.c | 2 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Feb 24 15:35:54 EST 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/lib/gis/parser.c
          Class
Item(Begins at: 108, Ends at:113)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Function
G_define_flag(Begins at: 179, Ends at:216)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |     * |      WARNING |         3 |
ParamNBR:     |       1 |     * |      WARNING |         1 |
CalledNBR:    |       4 |     * |      WARNING |         4 |
LOC:          |      38 |     * |      WARNING |        38 |
Conclusion:   | this function is a       WARNING           |
 at least 4 values are close to an outlier please consider revising code!
G_define_module(Begins at: 650, Ends at:663)
Complexity:   |       1 |    ** | BABY-MONSTER |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      14 |       |           OK |        14 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
G_define_option(Begins at: 235, Ends at:286)
Complexity:   |       3 |    ** | BABY-MONSTER |         3 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      52 |       |           OK |        52 |
G_define_standard_option(Begins at: 315, Ends at:641)
Complexity:   |      38 |     * |      WARNING |        38 |
CalledNBR:    |      43 |       |           OK |        43 |
LOC:          |     327 |       |           OK |       327 |
 at least 1 values are close to an outlier please consider revising code!
G_disable_interactive(Begins at: 158, Ends at:163)
Complexity:   |       1 |     * |      WARNING |         1 |
LOC:          |       6 |       |           OK |         6 |
G_gui(Begins at: 1978, Ends at:1993)
CalledNBR:    |       5 |     * |      WARNING |         5 |
LOC:          |      16 |     * |      WARNING |        16 |
 at least 3 values are close to an outlier please consider revising code!
G_gui_tcltk(Begins at: 1923, Ends at:1952)
Complexity:   |       6 |       |           OK |         6 |
CalledNBR:    |      12 |       |           OK |        12 |
LOC:          |      30 |       |           OK |        30 |
Conclusion:   | this function is a            OK           |
metrics are OK
G_gui_wx(Begins at: 1957, Ends at:1969)
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      13 |       |           OK |        13 |
G_parser(Begins at: 702, Ends at:963)
Complexity:   |      41 |       |           OK |        41 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      85 |       |           OK |        85 |
LOC:          |     262 |       |           OK |       262 |
metrics are OK
G_recreate_command(Begins at: 2779, Ends at:2878)
Complexity:   |      14 |     * |      WARNING |        14 |
CalledNBR:    |      26 |    ** | BABY-MONSTER |        26 |
LOC:          |     100 |    ** | BABY-MONSTER |       100 |
G_script(Begins at: 1701, Ends at:1813)
Complexity:   |      24 |     * |      WARNING |        24 |
CalledNBR:    |      46 |     * |      WARNING |        46 |
LOC:          |     113 |     * |      WARNING |       113 |
G_tcltk(Begins at: 1998, Ends at:2006)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       9 |       |           OK |         9 |
metrics are OK
G_usage(Begins at: 1013, Ends at:1184)
Complexity:   |      34 |       |           OK |        34 |
CalledNBR:    |      53 |       |           OK |        53 |
LOC:          |     172 |       |           OK |       172 |
metrics are OK
G_usage_html(Begins at: 1477, Ends at:1696)
Complexity:   |      42 |       |           OK |        42 |
LOC:          |     220 |     * |      WARNING |       220 |
G_usage_xml(Begins at: 1239, Ends at:1472)
Complexity:   |      31 |   *** |      MONSTER |        31 |
CalledNBR:    |      87 |   *** |      MONSTER |        87 |
LOC:          |     234 |   *** |      MONSTER |       234 |
Conclusion:   | this function is a       MONSTER           |
check_an_opt(Begins at: 2206, Ends at:2248)
Complexity:   |      10 |       |           OK |        10 |
ParamNBR:     |       4 |       |           OK |         4 |
CalledNBR:    |      13 |       |           OK |        13 |
LOC:          |      43 |       |           OK |        43 |
metrics are OK
check_double(Begins at: 2314, Ends at:2350)
Complexity:   |      14 |       |           OK |        14 |
LOC:          |      37 |       |           OK |        37 |
metrics are OK
check_int(Begins at: 2250, Ends at:2286)
CalledNBR:    |       6 |     * |      WARNING |         6 |
 at least 2 values are close to an outlier please consider revising code!
check_multiple_opts(Begins at: 2463, Ends at:2499)
Complexity:   |       8 |       |           OK |         8 |
CalledNBR:    |       5 |       |           OK |         5 |
metrics are OK
check_opts(Begins at: 2170, Ends at:2204)
Complexity:   |       7 |   *** |      MONSTER |         7 |
CalledNBR:    |       3 |   *** |      MONSTER |         3 |
LOC:          |      35 |   *** |      MONSTER |        35 |
check_overwrite(Begins at: 2502, Ends at:2565)
Complexity:   |      12 |    ** | BABY-MONSTER |        12 |
CalledNBR:    |      16 |    ** | BABY-MONSTER |        16 |
LOC:          |      64 |    ** | BABY-MONSTER |        64 |
check_required(Begins at: 2378, Ends at:2401)
Complexity:   |       4 |   *** |      MONSTER |         4 |
CalledNBR:    |       2 |   *** |      MONSTER |         2 |
LOC:          |      24 |    ** | BABY-MONSTER |        24 |
check_string(Begins at: 2352, Ends at:2376)
Complexity:   |       9 |       |           OK |         9 |
LOC:          |      25 |       |           OK |        25 |
metrics are OK
contains(Begins at: 2088, Ends at:2096)
Complexity:   |       3 |   *** |      MONSTER |         3 |
CalledNBR:    |       0 |   *** |      MONSTER |         0 |
LOC:          |       9 |   *** |      MONSTER |         9 |
generate_tcl(Begins at: 1820, Ends at:1918)
Complexity:   |      12 |   *** |      MONSTER |        12 |
CalledNBR:    |      34 |   *** |      MONSTER |        34 |
LOC:          |      99 |   *** |      MONSTER |        99 |
gis_prompt(Begins at: 2725, Ends at:2769)
Complexity:   |      11 |   *** |      MONSTER |        11 |
CalledNBR:    |      20 |   *** |      MONSTER |        20 |
LOC:          |      45 |   *** |      MONSTER |        45 |
interactive(Begins at: 2567, Ends at:2593)
Complexity:   |       6 |     * |      WARNING |         6 |
LOC:          |      27 |       |           OK |        27 |
interactive_flag(Begins at: 2595, Ends at:2604)
Complexity:   |       1 |       |           OK |         1 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
interactive_option(Begins at: 2606, Ends at:2693)
Complexity:   |      24 |   *** |      MONSTER |        24 |
CalledNBR:    |      37 |   *** |      MONSTER |        37 |
LOC:          |      88 |     * |      WARNING |        88 |
is_option(Begins at: 2098, Ends at:2111)
Complexity:   |       4 |       |           OK |         4 |
metrics are OK
print_escaped_for_html(Begins at: 1218, Ends at:1232)
LOC:          |      15 |       |           OK |        15 |
metrics are OK
print_escaped_for_xml(Begins at: 1194, Ends at:1211)
Complexity:   |       7 |     * |      WARNING |         7 |
LOC:          |      18 |       |           OK |        18 |
set_flag(Begins at: 2059, Ends at:2083)
metrics are OK
set_option(Begins at: 2113, Ends at:2168)
Complexity:   |       8 |     * |      WARNING |         8 |
CalledNBR:    |      13 |     * |      WARNING |        13 |
LOC:          |      56 |     * |      WARNING |        56 |
show(Begins at: 2045, Ends at:2057)
CalledNBR:    |       3 |       |           OK |         3 |
metrics are OK
show_options(Begins at: 2015, Ends at:2043)
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      29 |       |           OK |        29 |
split_gisprompt(Begins at: 2695, Ends at:2723)
ParamNBR:     |       4 |     * |      WARNING |         4 |
split_opts(Begins at: 2403, Ends at:2461)
Complexity:   |      10 |     * |      WARNING |        10 |
LOC:          |      59 |     * |      WARNING |        59 |
uses_new_gisprompt(Begins at: 966, Ends at:988)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      23 |       |           OK |        23 |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  check_double
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/gis/parser.c clones of check_double are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/gis/parser.c  check_int
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/gis/parser.c clones of check_int are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/gis/parser.c  check_double
____________________________________________
Threshold grass key metrics values at Tue Feb 24 15:39:33 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
