[GRASS-QA] GRASS QA: mmetz |index.c index.h rect.c | no clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Tue Feb 24 15:45:40 EST 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/lib/vector/rtree/index.c
Function
RTreeDeleteRect(Begins at: 262, Ends at:311)
| New Metrics |Old Metrics|
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 10 | * | WARNING | 10 |
LOC: | 50 | * | WARNING | 50 |
Conclusion: | this function is a WARNING |
at least 4 values are close to an outlier please consider revising code!
RTreeDeleteRect2(Begins at: 210, Ends at:254)
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 45 | * | WARNING | 45 |
at least 3 values are close to an outlier please consider revising code!
RTreeFreeListNode(Begins at: 184, Ends at:188)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 5 | | OK | 5 |
Conclusion: | this function is a OK |
metrics are OK
RTreeInsertRect(Begins at: 138, Ends at:172)
Complexity: | 3 | | OK | 3 |
LOC: | 35 | | OK | 35 |
at least 1 values are close to an outlier please consider revising code!
RTreeInsertRect2(Begins at: 81, Ends at:128)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 5 | * | WARNING | 5 |
LOC: | 48 | * | WARNING | 48 |
RTreeNewIndex(Begins at: 25, Ends at:32)
LOC: | 8 | | OK | 8 |
metrics are OK
RTreeNewListNode(Begins at: 178, Ends at:182)
CalledNBR: | 2 | | OK | 2 |
metrics are OK
RTreeReInsert(Begins at: 194, Ends at:202)
ParamNBR: | 2 | | OK | 2 |
LOC: | 9 | | OK | 9 |
metrics are OK
RTreeSearch(Begins at: 39, Ends at:70)
CalledNBR: | 7 | | OK | 7 |
LOC: | 32 | | OK | 32 |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
File :grass/branches/develbranch_6/lib/vector/rtree/index.h
Class
Branch(Begins at: 47, Ends at:51)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
ListNode(Begins at: 63, Ends at:67)
Class
Node(Begins at: 56, Ends at:61)
Class
Rect(Begins at: 40, Ends at:43)
Clone analysis:
File :grass/branches/develbranch_6/lib/vector/rtree/rect.c
Function
RTreeCombineRect(Begins at: 305, Ends at:325)
CalledNBR: | 5 | | OK | 5 |
LOC: | 21 | | OK | 21 |
metrics are OK
RTreeContained(Begins at: 352, Ends at:374)
CalledNBR: | 3 | | OK | 3 |
LOC: | 23 | | OK | 23 |
metrics are OK
RTreeInitRect(Begins at: 38, Ends at:45)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 0 | | OK | 0 |
metrics are OK
RTreeNullRect(Begins at: 52, Ends at:62)
LOC: | 11 | | OK | 11 |
metrics are OK
RTreeOverlap(Begins at: 331, Ends at:346)
LOC: | 16 | | OK | 16 |
metrics are OK
RTreePrintRect(Begins at: 130, Ends at:143)
LOC: | 14 | | OK | 14 |
metrics are OK
RTreeRectSphericalVolume(Begins at: 253, Ends at:269)
CalledNBR: | 4 | | OK | 4 |
LOC: | 17 | | OK | 17 |
metrics are OK
RTreeRectSurfaceArea(Begins at: 275, Ends at:298)
Complexity: | 5 | | OK | 5 |
LOC: | 24 | | OK | 24 |
metrics are OK
RTreeRectVolume(Begins at: 148, Ends at:162)
LOC: | 15 | | OK | 15 |
metrics are OK
sphere_volume(Begins at: 178, Ends at:185)
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Feb 24 15:49:19 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
