[GRASS-QA] GRASS QA: martinl |main.c plot1.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Jan 2 15:21:55 EST 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/display/d.vect/main.c
          Function
icon_files(Begins at: 32, Ends at:76)
              |          New Metrics           |Old Metrics|
Complexity:   |       8 |     * |      WARNING |         8 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      14 |     * |      WARNING |        14 |
LOC:          |      45 |     * |      WARNING |        45 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
main(Begins at: 78, Ends at:749)
Complexity:   |      83 |   *** |      MONSTER |        83 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     216 |   *** |      MONSTER |       216 |
LOC:          |     672 |   *** |      MONSTER |       672 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :grass/branches/develbranch_6/display/d.vect/plot1.c
          Function
local_plot_poly(Begins at: 48, Ends at:69)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      10 |     * |      WARNING |        10 |
LOC:          |      22 |       |           OK |        22 |
 at least 2 values are close to an outlier please consider revising code!
plot1(Begins at: 129, Ends at:530)
Complexity:   |      60 |   *** |      MONSTER |        60 |
ParamNBR:     |      18 |   *** |      MONSTER |        18 |
CalledNBR:    |      94 |   *** |      MONSTER |        94 |
LOC:          |     402 |   *** |      MONSTER |       402 |
plot_polygon(Begins at: 102, Ends at:124)
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      23 |       |           OK |        23 |
plot_polyline(Begins at: 74, Ends at:97)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      24 |       |           OK |        24 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Fri Jan 02 15:38:36 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
