[GRASS-QA] GRASS QA: glynn |do_graph.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Wed Jan 7 13:53:08 EST 2009
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/display/d.graph/do_graph.c
Function
check_alloc(Begins at: 254, Ends at:277)
| New Metrics |Old Metrics|
Complexity: | 4 | | OK | 4 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 24 | | OK | 24 |
Conclusion: | this function is a OK |
metrics are OK
do_color(Begins at: 97, Ends at:127)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 31 | | OK | 31 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
do_draw(Begins at: 49, Ends at:75)
CalledNBR: | 6 | | OK | 6 |
LOC: | 27 | | OK | 27 |
metrics are OK
do_icon(Begins at: 279, Ends at:328)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 18 | * | WARNING | 18 |
LOC: | 50 | * | WARNING | 50 |
at least 3 values are close to an outlier please consider revising code!
do_linewidth(Begins at: 129, Ends at:142)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 14 | | OK | 14 |
metrics are OK
do_move(Begins at: 77, Ends at:95)
LOC: | 19 | | OK | 19 |
metrics are OK
do_poly(Begins at: 145, Ends at:200)
Complexity: | 10 | * | WARNING | 10 |
ParamNBR: | 2 | | OK | 2 |
LOC: | 56 | * | WARNING | 56 |
do_rotate(Begins at: 228, Ends at:239)
LOC: | 12 | | OK | 12 |
metrics are OK
do_size(Begins at: 202, Ends at:226)
CalledNBR: | 3 | | OK | 3 |
LOC: | 25 | | OK | 25 |
metrics are OK
do_symbol(Begins at: 330, Ends at:433)
Complexity: | 11 | * | WARNING | 11 |
CalledNBR: | 41 | *** | MONSTER | 41 |
LOC: | 104 | ** | BABY-MONSTER | 104 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
do_text(Begins at: 241, Ends at:252)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 1 | | OK | 1 |
metrics are OK
set_graph_stuff(Begins at: 25, Ends at:37)
CalledNBR: | 0 | | OK | 0 |
LOC: | 13 | | OK | 13 |
metrics are OK
set_last_color(Begins at: 436, Ends at:449)
ParamNBR: | 4 | * | WARNING | 4 |
set_text_size(Begins at: 39, Ends at:47)
LOC: | 9 | | OK | 9 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Jan 07 14:10:52 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
