[GRASS-QA] GRASS QA: glynn |invert.c subcluster.c bouman.h eigen.c
...| 1 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Fri Jan 9 16:15:49 EST 2009
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/imagery/i.gensigset/invert.c
Function
invert(Begins at: 3, Ends at:38)
| New Metrics |Old Metrics|
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 36 | | OK | 36 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/imagery/i.gensigset/subcluster.c
Function
add_SubSigs(Begins at: 583, Ends at:616)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 34 | | OK | 34 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
compute_constants(Begins at: 508, Ends at:580)
Complexity: | 10 | * | WARNING | 10 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 73 | * | WARNING | 73 |
at least 3 values are close to an outlier please consider revising code!
copy_ClassSig(Begins at: 618, Ends at:632)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 15 | | OK | 15 |
copy_SubSig(Begins at: 635, Ends at:655)
LOC: | 21 | | OK | 21 |
distance(Begins at: 473, Ends at:505)
CalledNBR: | 6 | | OK | 6 |
LOC: | 33 | | OK | 33 |
list_Sig(Begins at: 657, Ends at:672)
LOC: | 16 | | OK | 16 |
Conclusion: | this function is a OK |
metrics are OK
loglike(Begins at: 451, Ends at:470)
LOC: | 20 | | OK | 20 |
print_class(Begins at: 675, Ends at:695)
metrics are OK
reduce_order(Begins at: 390, Ends at:448)
CalledNBR: | 9 | | OK | 9 |
LOC: | 59 | * | WARNING | 59 |
reestimate(Begins at: 255, Ends at:345)
Complexity: | 19 | ** | BABY-MONSTER | 19 |
LOC: | 91 | ** | BABY-MONSTER | 91 |
refine_clusters(Begins at: 191, Ends at:252)
Complexity: | 5 | | OK | 5 |
LOC: | 62 | * | WARNING | 62 |
regroup(Begins at: 348, Ends at:387)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 40 | | OK | 40 |
seed(Begins at: 119, Ends at:188)
Complexity: | 14 | ** | BABY-MONSTER | 14 |
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 70 | * | WARNING | 70 |
subcluster(Begins at: 27, Ends at:116)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 18 | * | WARNING | 18 |
LOC: | 90 | * | WARNING | 90 |
at least 4 values are close to an outlier please consider revising code!
Clone analysis:
File :grass/trunk/imagery/i.smap/bouman.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/imagery/i.smap/eigen.c
File :grass/trunk/imagery/i.smap/invert.c
File :grass/trunk/imagery/i.smap/model.c
File :grass/trunk/include/gisdefs.h
File :grass/trunk/include/gmath.h
File :grass/trunk/lib/gmath/eigen.c
Function
egcmp(Begins at: 135, Ends at:146)
Complexity: | 3 | | OK | 3 |
LOC: | 12 | | OK | 12 |
metrics are OK
egvorder2(Begins at: 70, Ends at:104)
Complexity: | 6 | * | WARNING | 6 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 35 | | OK | 35 |
at least 2 values are close to an outlier please consider revising code!
eigen(Begins at: 26, Ends at:54)
LOC: | 29 | | OK | 29 |
transpose2(Begins at: 119, Ends at:132)
LOC: | 14 | | OK | 14 |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/gmath/eigen.c clones of egcmp are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/gmath/jacobi.c egcmp
File :grass/trunk/lib/gmath/lu.c
Function
G_lubksb(Begins at: 70, Ends at:93)
LOC: | 24 | | OK | 24 |
G_ludcmp(Begins at: 8, Ends at:66)
Complexity: | 16 | ** | BABY-MONSTER | 16 |
CalledNBR: | 4 | | OK | 4 |
Clone analysis:
File :grass/trunk/lib/gmath/svd.c
Function
G_svbksb(Begins at: 236, Ends at:261)
ParamNBR: | 7 | ** | BABY-MONSTER | 7 |
LOC: | 26 | | OK | 26 |
G_svdcmp(Begins at: 15, Ends at:230)
Complexity: | 57 | *** | MONSTER | 57 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 19 | * | WARNING | 19 |
LOC: | 216 | *** | MONSTER | 216 |
Conclusion: | this function is a MONSTER |
G_svelim(Begins at: 265, Ends at:280)
metrics are OK
Clone analysis:
File :grass/trunk/lib/rst/interp_float/matrix.c
Function
IL_matrix_create(Begins at: 29, Ends at:162)
CalledNBR: | 10 | * | WARNING | 10 |
LOC: | 134 | ** | BABY-MONSTER | 134 |
Clone analysis:
File :grass/trunk/lib/rst/interp_float/ressegm2d.c
Function
IL_resample_interp_segments_2d(Begins at: 32, Ends at:480)
Complexity: | 56 | *** | MONSTER | 56 |
ParamNBR: | 25 | *** | MONSTER | 25 |
CalledNBR: | 58 | *** | MONSTER | 58 |
LOC: | 449 | *** | MONSTER | 449 |
input_data(Begins at: 484, Ends at:546)
ParamNBR: | 11 | *** | MONSTER | 11 |
LOC: | 63 | * | WARNING | 63 |
write_zeros(Begins at: 548, Ends at:610)
Clone analysis:
File :grass/trunk/lib/rst/interp_float/segmen2d.c
Function
IL_interp_segments_2d(Begins at: 16, Ends at:304)
Complexity: | 37 | *** | MONSTER | 37 |
ParamNBR: | 18 | *** | MONSTER | 18 |
CalledNBR: | 34 | ** | BABY-MONSTER | 34 |
LOC: | 289 | *** | MONSTER | 289 |
smallest_segment(Begins at: 306, Ends at:337)
LOC: | 32 | | OK | 32 |
Clone analysis:
File :grass/trunk/raster/r.param.scale/process.c
Function
process(Begins at: 24, Ends at:249)
Complexity: | 21 | *** | MONSTER | 21 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 42 | *** | MONSTER | 42 |
LOC: | 226 | *** | MONSTER | 226 |
Clone analysis:
File :grass/trunk/raster/r.resamp.rst/main.c
Function
clean(Begins at: 578, Ends at:593)
Complexity: | 13 | * | WARNING | 13 |
create_temp_file(Begins at: 542, Ends at:564)
LOC: | 23 | | OK | 23 |
metrics are OK
create_temp_files(Begins at: 566, Ends at:576)
Complexity: | 1 | *** | MONSTER | 1 |
CalledNBR: | 8 | *** | MONSTER | 8 |
LOC: | 11 | *** | MONSTER | 11 |
main(Begins at: 124, Ends at:540)
Complexity: | 44 | ** | BABY-MONSTER | 44 |
CalledNBR: | 167 | * | WARNING | 167 |
LOC: | 417 | | OK | 417 |
Clone analysis:
File :grass/trunk/vector/lidar/lidarlib/PolimiFunct.h
Class
Point(Begins at: 79, Ends at:86)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
Reg_dimens(Begins at: 70, Ends at:77)
Class
element(Begins at: 88, Ends at:93)
Clone analysis:
File :grass/trunk/vector/v.surf.rst/main.c
Function
clean_fatal_error(Begins at: 848, Ends at:875)
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 28 | | OK | 28 |
main(Begins at: 129, Ends at:802)
Complexity: | 99 | *** | MONSTER | 99 |
CalledNBR: | 291 | *** | MONSTER | 291 |
LOC: | 674 | *** | MONSTER | 674 |
print_tree(Begins at: 806, Ends at:844)
CalledNBR: | 7 | | OK | 7 |
LOC: | 39 | | OK | 39 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Fri Jan 09 16:34:00 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
