[GRASS-QA] GRASS QA: martinl |fancy.c local_proto.h local_proto.h
local_proto.h ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Wed Jul 1 05:56:26 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/display/d.title/fancy.c
Function
fancy(Begins at: 4, Ends at:19)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 16 | | OK | 16 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/display/d.title/local_proto.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/imagery/i.cca/local_proto.h
File :grass/trunk/imagery/i.gensig/local_proto.h
File :grass/trunk/imagery/i.his.rgb/globals.h
File :grass/trunk/imagery/i.modis.qc/mod09A1a.c
File :grass/trunk/imagery/i.modis.qc/mod09A1c.c
File :grass/trunk/imagery/i.modis.qc/mod09A1d.c
File :grass/trunk/imagery/i.modis.qc/mod09A1e.c
File :grass/trunk/imagery/i.modis.qc/mod09A1sa.c
File :grass/trunk/imagery/i.modis.qc/mod09A1sb.c
File :grass/trunk/imagery/i.modis.qc/mod09A1sc.c
File :grass/trunk/imagery/i.modis.qc/mod09A1sd.c
File :grass/trunk/imagery/i.modis.qc/mod09A1se.c
File :grass/trunk/imagery/i.modis.qc/mod09A1sf.c
File :grass/trunk/imagery/i.modis.qc/mod09A1sg.c
File :grass/trunk/imagery/i.modis.qc/mod09A1sh.c
File :grass/trunk/imagery/i.modis.qc/mod09A1si.c
File :grass/trunk/imagery/i.modis.qc/mod09A1sj.c
File :grass/trunk/imagery/i.modis.qc/mod09A1sk.c
File :grass/trunk/imagery/i.modis.qc/mod09Q1a.c
File :grass/trunk/imagery/i.modis.qc/mod09Q1b.c
File :grass/trunk/imagery/i.modis.qc/mod09Q1c.c
File :grass/trunk/imagery/i.modis.qc/mod09Q1d.c
File :grass/trunk/imagery/i.modis.qc/mod09Q1e.c
File :grass/trunk/imagery/i.modis.qc/mod09Q1f.c
File :grass/trunk/imagery/i.modis.qc/mod11A2a.c
File :grass/trunk/imagery/i.modis.qc/mod11A2b.c
File :grass/trunk/imagery/i.modis.qc/mod11A2c.c
File :grass/trunk/imagery/i.modis.qc/mod11A2d.c
File :grass/trunk/imagery/i.rgb.his/globals.h
File :grass/trunk/imagery/i.smap/bouman.h
File :grass/trunk/include/G3d.h
File :grass/trunk/include/gis.h
Class
Categories(Begins at: 452, Ends at:476)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
Cell_head(Begins at: 257, Ends at:279)
Class
Cell_stats(Begins at: 492, Ends at:507)
Class
Cell_stats_node(Begins at: 494, Ends at:500)
Class
Colors(Begins at: 322, Ends at:340)
Class
FPRange(Begins at: 527, Ends at:532)
Class
FPReclass(Begins at: 377, Ends at:399)
Class
FPReclass_table(Begins at: 367, Ends at:373)
Class
Flag(Begins at: 600, Ends at:608)
Class
GModule(Begins at: 610, Ends at:618)
Class
G_3dview(Begins at: 537, Ends at:562)
Class
Histogram(Begins at: 509, Ends at:518)
Class
Histogram_list(Begins at: 513, Ends at:517)
Class
History(Begins at: 478, Ends at:490)
Class
Key_Value(Begins at: 564, Ends at:570)
Class
Option(Begins at: 572, Ends at:598)
|NEW Metrics | 1 | 0 | 0 | 1 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 1 | 0 | 0 |
Class
Quant(Begins at: 409, Ends at:450)
Class
Quant_table(Begins at: 401, Ends at:407)
Class
Range(Begins at: 520, Ends at:525)
Class
Reclass(Begins at: 356, Ends at:365)
Class
TimeStamp(Begins at: 620, Ends at:624)
Class
_Color_Info_(Begins at: 295, Ends at:320)
Class
_Color_Rule_(Begins at: 281, Ends at:293)
Clone analysis:
File :grass/trunk/include/raster.h
File :grass/trunk/include/rasterdefs.h
File :grass/trunk/include/site.h
File :grass/trunk/include/stats.h
File :grass/trunk/lib/raster/color_init.c
File :grass/trunk/lib/raster/color_insrt.c
File :grass/trunk/lib/raster/color_invrt.c
File :grass/trunk/lib/raster/color_range.c
File :grass/trunk/lib/raster/color_rule_get.c
File :grass/trunk/lib/raster/color_shift.c
File :grass/trunk/lib/raster/history.c
File :grass/trunk/lib/raster/interp.c
File :grass/trunk/ps/ps.map/local_proto.h
File :grass/trunk/ps/ps.map/parse_list.c
Function
parse_val_list(Begins at: 24, Ends at:62)
Complexity: | 7 | * | WARNING | 7 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 39 | | OK | 39 |
at least 1 values are close to an outlier please consider revising code!
Clone analysis:
File :grass/trunk/ps/ps.map/ps_info.h
Class
PS_data(Begins at: 22, Ends at:72)
Clone analysis:
File :grass/trunk/raster/r.carve/enforce.h
Class
parms(Begins at: 49, Ends at:55)
Clone analysis:
File :grass/trunk/raster/r.cross/glob.h
File :grass/trunk/raster/r.describe/local_proto.h
File :grass/trunk/raster/r.describe/tree.c
Function
add_node_to_tree(Begins at: 49, Ends at:114)
Complexity: | 9 | * | WARNING | 9 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 66 | * | WARNING | 66 |
first_cat(Begins at: 156, Ends at:162)
CalledNBR: | 2 | | OK | 2 |
LOC: | 7 | | OK | 7 |
Conclusion: | this function is a OK |
metrics are OK
first_node(Begins at: 122, Ends at:132)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 11 | | OK | 11 |
metrics are OK
next_cat(Begins at: 164, Ends at:189)
Complexity: | 6 | * | WARNING | 6 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 26 | | OK | 26 |
next_node(Begins at: 134, Ends at:153)
Complexity: | 4 | | OK | 4 |
LOC: | 20 | | OK | 20 |
metrics are OK
plant_tree(Begins at: 38, Ends at:47)
LOC: | 10 | | OK | 10 |
metrics are OK
Clone analysis:
File :grass/trunk/raster/r.distance/defs.h
Class
CatEdgeList(Begins at: 27, Ends at:33)
Class
EdgeList(Begins at: 25, Ends at:37)
Class
Map(Begins at: 39, Ends at:46)
Class
Parms(Begins at: 48, Ends at:54)
Clone analysis:
File :grass/trunk/raster/r.distance/distance.c
Function
find_minimum_distance(Begins at: 27, Ends at:76)
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 11 | *** | MONSTER | 11 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 50 | * | WARNING | 50 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
null_distance(Begins at: 78, Ends at:166)
Complexity: | 14 | ** | BABY-MONSTER | 14 |
CalledNBR: | 27 | ** | BABY-MONSTER | 27 |
LOC: | 89 | * | WARNING | 89 |
Conclusion: | this function is a BABY-MONSTER |
Clone analysis:
File :grass/trunk/raster/r.distance/edges.c
Function
add_edge_cell(Begins at: 95, Ends at:136)
CalledNBR: | 6 | | OK | 6 |
LOC: | 42 | * | WARNING | 42 |
at least 3 values are close to an outlier please consider revising code!
cmp(Begins at: 146, Ends at:151)
LOC: | 6 | | OK | 6 |
metrics are OK
find_edge_cells(Begins at: 32, Ends at:93)
CalledNBR: | 23 | ** | BABY-MONSTER | 23 |
LOC: | 62 | * | WARNING | 62 |
init_edge_list(Begins at: 138, Ends at:144)
metrics are OK
print_edge_info(Begins at: 22, Ends at:30)
CalledNBR: | 3 | | OK | 3 |
LOC: | 9 | | OK | 9 |
metrics are OK
sort_edge_list(Begins at: 153, Ends at:158)
metrics are OK
Clone analysis:
File :grass/trunk/raster/r.distance/report.c
Function
report(Begins at: 21, Ends at:79)
CalledNBR: | 22 | * | WARNING | 22 |
LOC: | 59 | * | WARNING | 59 |
Clone analysis:
File :grass/trunk/raster/r.flow/r.flow.h
File :grass/trunk/raster/r.in.gridatb/local_proto.h
File :grass/trunk/raster/r.in.poly/getformat.c
Function
getformat(Begins at: 4, Ends at:54)
Complexity: | 10 | * | WARNING | 10 |
LOC: | 51 | * | WARNING | 51 |
Clone analysis:
File :grass/trunk/raster/r.info/local_proto.h
File :grass/trunk/raster/r.kappa/kappa.h
Class
_gstats_(Begins at: 5, Ends at:9)
Class
_layer_(Begins at: 11, Ends at:16)
Clone analysis:
File :grass/trunk/raster/r.li/r.li.daemon/daemon.h
Class
area_entry(Begins at: 107, Ends at:120)
Class
cell_memory_entry(Begins at: 51, Ends at:56)
Class
dcell_memory_entry(Begins at: 69, Ends at:74)
Class
fcell_memory_entry(Begins at: 87, Ends at:92)
Clone analysis:
File :grass/trunk/raster/r.li/r.li.daemon/GenericCell.h
File :grass/trunk/raster/r.los/delete.c
Function
delete(Begins at: 24, Ends at:94)
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 71 | * | WARNING | 71 |
Clone analysis:
File :grass/trunk/raster/r.los/mark_pts.c
Function
mark_visible_points(Begins at: 21, Ends at:47)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
LOC: | 27 | | OK | 27 |
Clone analysis:
File :grass/trunk/raster/r.mapcalc/mapcalc.h
File :grass/trunk/raster/r.mapcalc/xrand.c
Function
f_rand(Begins at: 19, Ends at:95)
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 77 | * | WARNING | 77 |
Clone analysis:
File :grass/trunk/raster/r.mapcalc/xrowcol.c
Function
f_col(Begins at: 13, Ends at:28)
f_depth(Begins at: 48, Ends at:64)
LOC: | 17 | | OK | 17 |
f_row(Begins at: 30, Ends at:46)
Clone analysis:
File :grass/trunk/raster/r.mfilter/filter.h
File :grass/trunk/raster/r.neighbors/ncb.h
Class
ncb(Begins at: 2, Ends at:15)
Clone analysis:
File :grass/trunk/raster/r.out.gridatb/local_proto.h
File :grass/trunk/raster/r.param.scale/param.h
File :grass/trunk/raster/r.profile/local_proto.h
File :grass/trunk/raster/r.quant/global.h
File :grass/trunk/raster/r.random/local_proto.h
Class
RASTER_MAP_PTR(Begins at: 13, Ends at:17)
Class
RASTER_PTR(Begins at: 5, Ends at:11)
Class
rr_state(Begins at: 24, Ends at:32)
Clone analysis:
File :grass/trunk/raster/r.random.cells/ransurf.h
File :grass/trunk/raster/r.random.surface/ransurf.h
File :grass/trunk/raster/r.reclass/rule.h
File :grass/trunk/raster/r.recode/global.h
File :grass/trunk/raster/r.report/global.h
Class
_gstats_(Begins at: 25, Ends at:30)
Class
_layer_(Begins at: 13, Ends at:20)
Class
_units_(Begins at: 36, Ends at:44)
Clone analysis:
File :grass/trunk/raster/r.report/main.c
Function
main(Begins at: 57, Ends at:76)
metrics are OK
Clone analysis:
File :grass/trunk/raster/r.report/parse.c
Function
match(Begins at: 270, Ends at:278)
parse_command_line(Begins at: 6, Ends at:196)
Complexity: | 15 | ** | BABY-MONSTER | 15 |
CalledNBR: | 56 | *** | MONSTER | 56 |
LOC: | 191 | *** | MONSTER | 191 |
parse_layer(Begins at: 232, Ends at:268)
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 37 | | OK | 37 |
parse_units(Begins at: 198, Ends at:230)
CalledNBR: | 10 | * | WARNING | 10 |
LOC: | 33 | | OK | 33 |
Clone analysis:
File :grass/trunk/raster/r.report/stats.c
Function
die(Begins at: 95, Ends at:100)
metrics are OK
get_stats(Begins at: 8, Ends at:93)
Complexity: | 23 | *** | MONSTER | 23 |
CalledNBR: | 39 | *** | MONSTER | 39 |
LOC: | 86 | * | WARNING | 86 |
Clone analysis:
File :grass/trunk/raster/r.ros/spot_dist.c
File :grass/trunk/raster/r.spread/select_linksB.c
File :grass/trunk/raster/r.spread/spot.c
File :grass/trunk/raster/r.spread/spread.c
File :grass/trunk/raster/r.surf.contour/contour.h
File :grass/trunk/raster/r.surf.idw/main.h
File :grass/trunk/raster/r.thin/local_proto.h
File :grass/trunk/raster/r.water.outlet/basin.h
File :grass/trunk/raster/r.watershed/seg/cseg.h
File :grass/trunk/raster3d/base/mask_functions.h
File :grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c
Function
Create_AuxEdge_Table(Begins at: 507, Ends at:542)
Complexity: | 2 | *** | MONSTER | 2 |
ParamNBR: | 1 | *** | MONSTER | 1 |
CalledNBR: | 18 | *** | MONSTER | 18 |
LOC: | 36 | *** | MONSTER | 36 |
Create_Interpolation_Table(Begins at: 556, Ends at:584)
CalledNBR: | 14 | * | WARNING | 14 |
LOC: | 29 | | OK | 29 |
Drop_Aux_Table(Begins at: 544, Ends at:553)
CalledNBR: | 4 | * | WARNING | 4 |
Get_Gradient(Begins at: 146, Ends at:169)
ParamNBR: | 4 | | OK | 4 |
LOC: | 24 | | OK | 24 |
metrics are OK
Insert(Begins at: 401, Ends at:417)
Insert_Interpolation(Begins at: 419, Ends at:433)
LOC: | 15 | | OK | 15 |
Select(Begins at: 452, Ends at:504)
Complexity: | 6 | | OK | 6 |
CalledNBR: | 22 | | OK | 22 |
LOC: | 53 | | OK | 53 |
UpDate(Begins at: 436, Ends at:450)
Complexity: | 1 | * | WARNING | 1 |
LOC: | 15 | * | WARNING | 15 |
at least 4 values are close to an outlier please consider revising code!
classification(Begins at: 171, Ends at:399)
Complexity: | 25 | | OK | 25 |
ParamNBR: | 16 | * | WARNING | 16 |
CalledNBR: | 58 | | OK | 58 |
LOC: | 229 | | OK | 229 |
edge_detection(Begins at: 34, Ends at:144)
ParamNBR: | 10 | *** | MONSTER | 10 |
CalledNBR: | 32 | ** | BABY-MONSTER | 32 |
LOC: | 111 | ** | BABY-MONSTER | 111 |
Clone analysis:
File :grass/trunk/vector/v.to.rast/local.h
____________________________________________
Threshold grass key metrics values at Wed Jul 01 05:44:01 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
