[GRASS-QA] GRASS QA: hamish |local_proto.h main.c printwindow.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Jul 1 08:01:41 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/general/g.region/local_proto.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/general/g.region/main.c
          Function
die(Begins at: 826, Ends at:832)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       7 |       |           OK |         7 |
Conclusion:   | this function is a            OK           |
metrics are OK
llinfo(Begins at: 845, Ends at:854)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      10 |       |           OK |        10 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
main(Begins at: 29, Ends at:824)
Complexity:   |     120 |   *** |      MONSTER |       120 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     259 |   *** |      MONSTER |       259 |
LOC:          |     796 |   *** |      MONSTER |       796 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
nsew(Begins at: 834, Ends at:843)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       6 |       |           OK |         6 |
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/general/g.region/printwindow.c
          Function
print_window(Begins at: 8, Ends at:653)
Complexity:   |      71 |   *** |      MONSTER |        71 |
CalledNBR:    |     232 |   *** |      MONSTER |       232 |
LOC:          |     646 |   *** |      MONSTER |       646 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Wed Jul 01 07:49:14 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
