[GRASS-QA] GRASS QA: martinl |main.c | 4 clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Wed Jul 8 11:30:08 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/db/db.execute/main.c
Function
get_stmt(Begins at: 136, Ends at:163)
| New Metrics |Old Metrics|
Complexity: | 4 | | OK | 4 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 28 | | OK | 28 |
Conclusion: | this function is a OK |
metrics are OK
main(Begins at: 37, Ends at:91)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 25 | ** | BABY-MONSTER | 25 |
LOC: | 55 | * | WARNING | 55 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
parse_command_line(Begins at: 94, Ends at:133)
CalledNBR: | 15 | * | WARNING | 15 |
LOC: | 40 | | OK | 40 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
stmt_is_empty(Begins at: 166, Ends at:171)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 6 | | OK | 6 |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
main parse_command_line parse_command_line
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.execute/main.c clones of main are:
/var/project-manager/grass/grassSVN/grass/trunk/db/base/execute.c main
/var/project-manager/grass/grassSVN/grass/trunk/db/db.execute/execute.c main
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.execute/main.c clones of parse_command_line are:
/var/project-manager/grass/grassSVN/grass/trunk/db/base/execute.c parse_command_line
/var/project-manager/grass/grassSVN/grass/trunk/db/db.execute/execute.c parse_command_line
____________________________________________
Threshold grass key metrics values at Wed Jul 08 11:14:46 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
