[GRASS-QA] GRASS QA: martinl |main.c main.c gis.h parser.c | 8 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Jul 8 11:52:18 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/db/db.connect/main.c
          Function
main(Begins at: 30, Ends at:174)
              |          New Metrics           |Old Metrics|
Complexity:   |      12 |     * |      WARNING |        12 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      39 |   *** |      MONSTER |        39 |
LOC:          |     145 |   *** |      MONSTER |       145 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file has 2 potentially cloned functions:
  main
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.connect/main.c clones of main are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/connect.c  main
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.connect/connect.c  main
          File :grass/trunk/db/db.execute/main.c
          Function
get_stmt(Begins at: 136, Ends at:163)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      28 |       |           OK |        28 |
Conclusion:   | this function is a            OK           |
metrics are OK
main(Begins at: 37, Ends at:91)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |      25 |    ** | BABY-MONSTER |        25 |
LOC:          |      55 |     * |      WARNING |        55 |
Conclusion:   | this function is a  BABY-MONSTER           |
parse_command_line(Begins at: 94, Ends at:133)
CalledNBR:    |      15 |     * |      WARNING |        15 |
LOC:          |      40 |       |           OK |        40 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
stmt_is_empty(Begins at: 166, Ends at:171)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       6 |       |           OK |         6 |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
  main  parse_command_line  parse_command_line
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.execute/main.c clones of main are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/execute.c  main
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.execute/execute.c  main
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.execute/main.c clones of parse_command_line are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/execute.c  parse_command_line
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.execute/execute.c  parse_command_line
          File :grass/trunk/include/gis.h
          Class
Categories(Begins at: 452, Ends at:476)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
Cell_head(Begins at: 257, Ends at:279)
          Class
Cell_stats(Begins at: 492, Ends at:507)
          Class
Cell_stats_node(Begins at: 494, Ends at:500)
          Class
Colors(Begins at: 322, Ends at:340)
          Class
FPRange(Begins at: 527, Ends at:532)
          Class
FPReclass(Begins at: 377, Ends at:399)
          Class
FPReclass_table(Begins at: 367, Ends at:373)
          Class
Flag(Begins at: 600, Ends at:608)
          Class
GModule(Begins at: 610, Ends at:618)
          Class
G_3dview(Begins at: 537, Ends at:562)
          Class
Histogram(Begins at: 509, Ends at:518)
          Class
Histogram_list(Begins at: 513, Ends at:517)
          Class
History(Begins at: 478, Ends at:490)
          Class
Key_Value(Begins at: 564, Ends at:570)
          Class
Option(Begins at: 572, Ends at:598)
|NEW Metrics |      1 |      0 |      0 |      1 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      1 |      0 |      0 |
          Class
Quant(Begins at: 409, Ends at:450)
          Class
Quant_table(Begins at: 401, Ends at:407)
          Class
Range(Begins at: 520, Ends at:525)
          Class
Reclass(Begins at: 356, Ends at:365)
          Class
TimeStamp(Begins at: 620, Ends at:624)
          Class
_Color_Info_(Begins at: 295, Ends at:320)
          Class
_Color_Rule_(Begins at: 281, Ends at:293)
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/lib/gis/parser.c
          Class
Item(Begins at: 109, Ends at:114)
          Function
G_define_flag(Begins at: 176, Ends at:213)
Complexity:   |       3 |     * |      WARNING |         3 |
ParamNBR:     |       1 |     * |      WARNING |         1 |
CalledNBR:    |       4 |     * |      WARNING |         4 |
LOC:          |      38 |     * |      WARNING |        38 |
 at least 4 values are close to an outlier please consider revising code!
G_define_module(Begins at: 649, Ends at:662)
Complexity:   |       1 |    ** | BABY-MONSTER |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      14 |       |           OK |        14 |
G_define_option(Begins at: 232, Ends at:283)
Complexity:   |       3 |    ** | BABY-MONSTER |         3 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      52 |       |           OK |        52 |
G_define_standard_option(Begins at: 312, Ends at:640)
Complexity:   |      38 |     * |      WARNING |        38 |
CalledNBR:    |      43 |       |           OK |        43 |
LOC:          |     329 |       |           OK |       329 |
G_disable_interactive(Begins at: 155, Ends at:160)
Complexity:   |       1 |     * |      WARNING |         1 |
G_gui(Begins at: 1973, Ends at:1988)
CalledNBR:    |       5 |     * |      WARNING |         5 |
LOC:          |      16 |     * |      WARNING |        16 |
 at least 3 values are close to an outlier please consider revising code!
G_gui_tcltk(Begins at: 1918, Ends at:1947)
Complexity:   |       6 |       |           OK |         6 |
CalledNBR:    |      12 |       |           OK |        12 |
LOC:          |      30 |       |           OK |        30 |
metrics are OK
G_gui_wx(Begins at: 1952, Ends at:1964)
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      13 |       |           OK |        13 |
G_parser(Begins at: 701, Ends at:955)
Complexity:   |      41 |       |           OK |        41 |
CalledNBR:    |      83 |       |           OK |        83 |
LOC:          |     255 |       |           OK |       255 |
metrics are OK
G_recreate_command(Begins at: 2600, Ends at:2699)
Complexity:   |      14 |     * |      WARNING |        14 |
CalledNBR:    |      26 |    ** | BABY-MONSTER |        26 |
LOC:          |     100 |    ** | BABY-MONSTER |       100 |
G_script(Begins at: 1696, Ends at:1808)
Complexity:   |      24 |     * |      WARNING |        24 |
CalledNBR:    |      46 |     * |      WARNING |        46 |
LOC:          |     113 |     * |      WARNING |       113 |
G_tcltk(Begins at: 1993, Ends at:2001)
Complexity:   |       3 |       |           OK |         3 |
LOC:          |       9 |       |           OK |         9 |
metrics are OK
G_usage(Begins at: 1008, Ends at:1179)
Complexity:   |      34 |       |           OK |        34 |
CalledNBR:    |      53 |       |           OK |        53 |
LOC:          |     172 |       |           OK |       172 |
metrics are OK
G_usage_html(Begins at: 1472, Ends at:1691)
Complexity:   |      42 |       |           OK |        42 |
CalledNBR:    |      85 |       |           OK |        85 |
LOC:          |     220 |     * |      WARNING |       220 |
G_usage_xml(Begins at: 1234, Ends at:1467)
Complexity:   |      31 |   *** |      MONSTER |        31 |
CalledNBR:    |      87 |   *** |      MONSTER |        87 |
LOC:          |     234 |   *** |      MONSTER |       234 |
check_an_opt(Begins at: 2201, Ends at:2243)
Complexity:   |      10 |       |           OK |        10 |
ParamNBR:     |       4 |       |           OK |         4 |
CalledNBR:    |      13 |       |           OK |        13 |
LOC:          |      43 |       |           OK |        43 |
metrics are OK
check_double(Begins at: 2309, Ends at:2345)
Complexity:   |      14 |       |           OK |        14 |
LOC:          |      37 |       |           OK |        37 |
metrics are OK
check_int(Begins at: 2245, Ends at:2281)
CalledNBR:    |       6 |     * |      WARNING |         6 |
 at least 2 values are close to an outlier please consider revising code!
check_multiple_opts(Begins at: 2457, Ends at:2492)
Complexity:   |       8 |       |           OK |         8 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      36 |       |           OK |        36 |
metrics are OK
check_opts(Begins at: 2165, Ends at:2199)
Complexity:   |       7 |   *** |      MONSTER |         7 |
CalledNBR:    |       3 |   *** |      MONSTER |         3 |
LOC:          |      35 |   *** |      MONSTER |        35 |
check_overwrite(Begins at: 2495, Ends at:2560)
Complexity:   |      12 |    ** | BABY-MONSTER |        12 |
CalledNBR:    |      16 |    ** | BABY-MONSTER |        16 |
LOC:          |      66 |    ** | BABY-MONSTER |        66 |
check_required(Begins at: 2373, Ends at:2395)
Complexity:   |       4 |   *** |      MONSTER |         4 |
CalledNBR:    |       2 |   *** |      MONSTER |         2 |
LOC:          |      23 |    ** | BABY-MONSTER |        23 |
check_string(Begins at: 2347, Ends at:2371)
Complexity:   |       9 |       |           OK |         9 |
LOC:          |      25 |       |           OK |        25 |
metrics are OK
contains(Begins at: 2083, Ends at:2091)
Complexity:   |       3 |   *** |      MONSTER |         3 |
CalledNBR:    |       0 |   *** |      MONSTER |         0 |
LOC:          |       9 |   *** |      MONSTER |         9 |
generate_tcl(Begins at: 1815, Ends at:1913)
Complexity:   |      12 |   *** |      MONSTER |        12 |
CalledNBR:    |      34 |   *** |      MONSTER |        34 |
LOC:          |      99 |   *** |      MONSTER |        99 |
is_option(Begins at: 2093, Ends at:2106)
LOC:          |      14 |   *** |      MONSTER |        14 |
print_escaped_for_html(Begins at: 1213, Ends at:1227)
Complexity:   |       4 |     * |      WARNING |         4 |
LOC:          |      15 |       |           OK |        15 |
print_escaped_for_xml(Begins at: 1189, Ends at:1206)
Complexity:   |       7 |       |           OK |         7 |
LOC:          |      18 |       |           OK |        18 |
metrics are OK
set_flag(Begins at: 2054, Ends at:2078)
CalledNBR:    |       4 |   *** |      MONSTER |         4 |
LOC:          |      25 |    ** | BABY-MONSTER |        25 |
set_option(Begins at: 2108, Ends at:2163)
LOC:          |      56 |       |           OK |        56 |
metrics are OK
show(Begins at: 2040, Ends at:2052)
CalledNBR:    |       3 |       |           OK |         3 |
metrics are OK
show_options(Begins at: 2010, Ends at:2038)
CalledNBR:    |      11 |       |           OK |        11 |
LOC:          |      29 |       |           OK |        29 |
split_gisprompt(Begins at: 2562, Ends at:2590)
metrics are OK
split_opts(Begins at: 2397, Ends at:2455)
Complexity:   |      10 |     * |      WARNING |        10 |
LOC:          |      59 |     * |      WARNING |        59 |
uses_new_gisprompt(Begins at: 958, Ends at:983)
LOC:          |      26 |       |           OK |        26 |
metrics are OK
Clone analysis:
  check_double
In /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/parser.c clones of check_double are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/parser.c  check_int
In /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/parser.c clones of check_int are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/parser.c  check_double
____________________________________________
Threshold grass key metrics values at Wed Jul 08 11:36:55 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
