[GRASS-QA] GRASS QA: martinl |rowio.h fileno.c forget.c get.c ...|
no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Fri Jul 10 17:12:24 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/include/rowio.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/lib/rowio/fileno.c
Function
rowio_fileno(Begins at: 13, Ends at:16)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 4 | | OK | 4 |
Conclusion: | this function is a OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/rowio/forget.c
Function
rowio_forget(Begins at: 3, Ends at:15)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 2 | | OK | 2 |
LOC: | 13 | | OK | 13 |
metrics are OK
Clone analysis:
File :grass/trunk/lib/rowio/get.c
Function
my_select(Begins at: 92, Ends at:102)
Complexity: | 2 | | OK | 2 |
LOC: | 11 | | OK | 11 |
metrics are OK
pageout(Begins at: 82, Ends at:90)
Complexity: | 3 | | OK | 3 |
LOC: | 9 | | OK | 9 |
metrics are OK
rowio_flush(Begins at: 74, Ends at:80)
CalledNBR: | 1 | | OK | 1 |
LOC: | 7 | | OK | 7 |
metrics are OK
rowio_get(Begins at: 31, Ends at:72)
Complexity: | 10 | * | WARNING | 10 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 42 | * | WARNING | 42 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
File :grass/trunk/lib/rowio/put.c
Function
rowio_put(Begins at: 27, Ends at:41)
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 15 | | OK | 15 |
at least 1 values are close to an outlier please consider revising code!
Clone analysis:
File :grass/trunk/lib/rowio/release.c
Function
rowio_release(Begins at: 5, Ends at:15)
CalledNBR: | 2 | | OK | 2 |
metrics are OK
Clone analysis:
File :grass/trunk/lib/rowio/setup.c
Function
rowio_setup(Begins at: 28, Ends at:57)
ParamNBR: | 14 | *** | MONSTER | 14 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 30 | | OK | 30 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
File :grass/trunk/raster/r.mfilter/execute.c
Function
execute_filter(Begins at: 6, Ends at:120)
Complexity: | 18 | ** | BABY-MONSTER | 18 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 17 | * | WARNING | 17 |
LOC: | 115 | ** | BABY-MONSTER | 115 |
Conclusion: | this function is a BABY-MONSTER |
Clone analysis:
File :grass/trunk/raster/r.mfilter/perform.c
Function
perform_filter(Begins at: 9, Ends at:102)
Complexity: | 14 | ** | BABY-MONSTER | 14 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 36 | ** | BABY-MONSTER | 36 |
LOC: | 94 | ** | BABY-MONSTER | 94 |
Clone analysis:
File :grass/trunk/raster/r.thin/io.c
Function
close_file(Begins at: 155, Ends at:187)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 19 | * | WARNING | 19 |
LOC: | 33 | | OK | 33 |
get_a_row(Begins at: 56, Ends at:61)
LOC: | 6 | | OK | 6 |
metrics are OK
map_size(Begins at: 189, Ends at:196)
LOC: | 8 | | OK | 8 |
open_file(Begins at: 84, Ends at:153)
Complexity: | 12 | | OK | 12 |
CalledNBR: | 36 | | OK | 36 |
LOC: | 70 | | OK | 70 |
metrics are OK
put_a_row(Begins at: 63, Ends at:69)
ParamNBR: | 2 | * | WARNING | 2 |
read_row(Begins at: 72, Ends at:76)
LOC: | 5 | | OK | 5 |
write_row(Begins at: 78, Ends at:82)
Complexity: | 1 | * | WARNING | 1 |
ParamNBR: | 4 | | OK | 4 |
CalledNBR: | 2 | ** | BABY-MONSTER | 2 |
LOC: | 5 | * | WARNING | 5 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Fri Jul 10 16:56:11 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
