[GRASS-QA] GRASS QA: mmetz |build_nat.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Mon Jul 13 02:58:54 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/vector/Vlib/build_nat.c
          Function
Vect_attach_centroids(Begins at: 332, Ends at:413)
              |          New Metrics           |Old Metrics|
Complexity:   |       9 |     * |      WARNING |         9 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      82 |     * |      WARNING |        82 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
Vect_attach_isle(Begins at: 261, Ends at:288)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      28 |       |           OK |        28 |
Conclusion:   | this function is a            OK           |
metrics are OK
Vect_attach_isles(Begins at: 298, Ends at:322)
LOC:          |      25 |       |           OK |        25 |
metrics are OK
Vect_build_line_area(Begins at: 40, Ends at:118)
Complexity:   |      10 |     * |      WARNING |        10 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      26 |    ** | BABY-MONSTER |        26 |
LOC:          |      79 |     * |      WARNING |        79 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Vect_build_nat(Begins at: 425, Ends at:677)
Complexity:   |      42 |   *** |      MONSTER |        42 |
CalledNBR:    |      59 |   *** |      MONSTER |        59 |
LOC:          |     253 |   *** |      MONSTER |       253 |
Conclusion:   | this function is a       MONSTER           |
Vect_isle_find_area(Begins at: 129, Ends at:251)
Complexity:   |      11 |     * |      WARNING |        11 |
CalledNBR:    |      27 |    ** | BABY-MONSTER |        27 |
LOC:          |     123 |    ** | BABY-MONSTER |       123 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Mon Jul 13 02:41:44 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
