[GRASS-QA] GRASS QA: martinl |mapset_nme.c | 1 clones | 0 monsters
|0 warnings
soccerlab.info at gmail.com
Thu Jun 4 15:18:07 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/gis/mapset_nme.c
Function
G__create_alt_search_path(Begins at: 106, Ends at:114)
| New Metrics |Old Metrics|
Complexity: | 1 | * | WARNING | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 0 | * | WARNING | 0 |
LOC: | 9 | | OK | 9 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
G__mapset_name(Begins at: 36, Ends at:51)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 16 | | OK | 16 |
Conclusion: | this function is a OK |
metrics are OK
G__switch_search_path(Begins at: 121, Ends at:136)
LOC: | 16 | * | WARNING | 16 |
at least 3 values are close to an outlier please consider revising code!
G_add_mapset_to_search_path(Begins at: 219, Ends at:228)
CalledNBR: | 2 | | OK | 2 |
LOC: | 10 | | OK | 10 |
metrics are OK
G_available_mapsets(Begins at: 157, Ends at:209)
Complexity: | 8 | | OK | 8 |
CalledNBR: | 16 | | OK | 16 |
LOC: | 53 | | OK | 53 |
metrics are OK
G_reset_mapsets(Begins at: 143, Ends at:148)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 6 | | OK | 6 |
metrics are OK
get_list_of_mapsets(Begins at: 53, Ends at:85)
Complexity: | 6 | | OK | 6 |
CalledNBR: | 11 | | OK | 11 |
LOC: | 33 | | OK | 33 |
metrics are OK
new_mapset(Begins at: 87, Ends at:99)
CalledNBR: | 3 | | OK | 3 |
LOC: | 13 | | OK | 13 |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/mapset_nme.c clones of G__switch_search_path are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/gis/env.c G__switch_env
____________________________________________
Threshold grass key metrics values at Thu Jun 04 15:15:39 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
