[GRASS-QA] GRASS QA: hamish |mapset_nme.c | 1 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Jun 4 16:24:42 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/lib/gis/mapset_nme.c
          Function
G__create_alt_search_path(Begins at: 106, Ends at:114)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       9 |       |           OK |         9 |
Conclusion:   | this function is a            OK           |
metrics are OK
G__mapset_name(Begins at: 36, Ends at:51)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      16 |       |           OK |        16 |
metrics are OK
G__switch_search_path(Begins at: 121, Ends at:136)
metrics are OK
G_add_mapset_to_search_path(Begins at: 219, Ends at:228)
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
G_available_mapsets(Begins at: 157, Ends at:209)
Complexity:   |       8 |     * |      WARNING |         8 |
CalledNBR:    |      16 |     * |      WARNING |        16 |
LOC:          |      53 |     * |      WARNING |        53 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
G_reset_mapsets(Begins at: 143, Ends at:148)
LOC:          |       6 |       |           OK |         6 |
metrics are OK
get_list_of_mapsets(Begins at: 53, Ends at:85)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      33 |       |           OK |        33 |
 at least 2 values are close to an outlier please consider revising code!
new_mapset(Begins at: 87, Ends at:99)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      13 |       |           OK |        13 |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/gis/mapset_nme.c clones of G__switch_search_path are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/gis/env.c  G__switch_env
____________________________________________
Threshold grass key metrics values at Thu Jun 04 16:22:13 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
