[GRASS-QA] GRASS QA: martinl |file.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Jun 4 16:38:55 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/vector/diglib/file.c
          Function
dig_fflush(Begins at: 85, Ends at:93)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       9 |       |           OK |         9 |
Conclusion:   | this function is a            OK           |
metrics are OK
dig_file_free(Begins at: 232, Ends at:239)
LOC:          |       8 |       |           OK |         8 |
metrics are OK
dig_file_init(Begins at: 138, Ends at:147)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
dig_file_load(Begins at: 154, Ends at:226)
Complexity:   |      11 |     * |      WARNING |        11 |
CalledNBR:    |      18 |     * |      WARNING |        18 |
LOC:          |      73 |     * |      WARNING |        73 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
dig_fread(Begins at: 99, Ends at:119)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      21 |       |           OK |        21 |
 at least 1 values are close to an outlier please consider revising code!
dig_fseek(Begins at: 47, Ends at:65)
Complexity:   |       6 |     * |      WARNING |         6 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
LOC:          |      19 |       |           OK |        19 |
 at least 2 values are close to an outlier please consider revising code!
dig_ftell(Begins at: 35, Ends at:41)
LOC:          |       7 |       |           OK |         7 |
metrics are OK
dig_fwrite(Begins at: 125, Ends at:132)
dig_rewind(Begins at: 71, Ends at:79)
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Thu Jun 04 16:36:27 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
